Swivel top tool table
Railcab
>Has anyone built this type of tool stand that lets you mount two tools in one cabinet. I believe it was in Wood Magazine. If so can you tell me if it works and worth the time to build it? thanks
Re: Swivel top tool table
Gerry Wittenberg now in Surrey
>I looked at those in Wood Mag and thought that they would do the job and about that time I got diddled out of a shop. My latest issue of ShopNotes (Vol 17 Issue 102) has some ideas that look interesting. There is a pivoting tool station similar in design to the Wood offering, a slide out shelf using full extension slides, a stacking tool stand for smaller bench tools and a caster/handle kind of a deal.
Gerry, still shopless........
I Built Wood's Version
>Good Evening Railcab,
They do work and are worth having if you are cramped for space. The weight and size of the tools are an important consideration when mounted on/under a small table. I used a small disc/belt sander on one side, and a Grizzly 70 rpm wet wheel grinder/sharpener on the other. I learned it was wise to insure the electrical cords weren't caught in the pivot, and that it was smart to drain the water out of the wet wheel tub before setting the table up for sanding. :<)
George
