Cleaning wide belt sander belts
Howard in Bethesda
>Is it possible to clean sander belts by soaking in a cleaning solution? If so, what solution would you recommend?
Thanks
Howard
Re: Cleaning wide belt sander belts
Howard in Bethesda
>Thanks
Do you use full strength or dilute?
Howard
>Any soapy aqueus solution will work, even plain water. You can give it a boost by adding a little Dawn or shampoo/conditioner.
Clint
Ken Oakley-Sunny St. Cloud, Fla
>I dilute. Put about 3 oz in bucket and rest water. Soak belt overnight and the rinse. Hang to dry
