Re: Know any DIY books/websites for Video Install? *LINK*
>It should be just RG-6 coax cable - available at the big box stores.
You will need a big splitter switch as your "hub" - if you are going with DirecTV, you had better check with them as to what it should be. Anyway, you can run all your wire to your "switch" area. Here is a URL from DirecTV on installation
Chad Pearson
>When I had my DirecTV installed I ran the satellite cable (from the dish) to a point in the basement where I could install a hub (splitter). I then ran coax (think your basic cable TV cord) from that hub point to any potential area that I thought I might install a TV in the future. I terminated each unused cable with a box and cover plate.
Keep in mind that the simple 4 dollar cable tv splitter will not work for DirecTV. The folks who sell you the dish will point you to the right equipment.
Remember to label all of the cords terminating at your hub.
>I've installed cable TV, cable modem, ISDN, security systems, satellite TV, and satellite internet mostly for my own use and occasionally for a friend and over the years have made many cables for my video production work. When making any kind of coax cable, whether video or BNC, I always bought a large roll of cable, cut to length, and a pile of connectors. These days video cable connectors don't usually require a crimper but do often require a special little tool depending on the type. If you have a good local electronics/security supply house they should have everything you need plus advice. I've bought cable at Lowe's as well. You may be able to buy supplies from your local cable TV or satellite installation companies. Sometimes if you are real nice and friendly they will even give you the ends of rolls, connectors, etc. :)
The most important thing I can recommend is to use very high quality splitters and cable, and most important, use high quality cable connectors and make the connections properly. More bad signals can be traced to poor connectors than anything else. The best connectors have a waterproof gel that inhibits corrosion. Be careful not to crimp the cable if fastening with staples. Those plastic hooks with a nail are good.
Make sure you use the right cable for the application.
I don't know the maximum lengths but with quality components and a good signal I have branches over 100' at this house.
I've found the powered amplified splitters mostly useless. Maybe you can rent or borrow a signal strength meter. Without one, getting too little (or too much) signal may be a problem that's hard to diagnose. Every time you split the signal will be reduced. On one cable TV/internet installation in a previous house I had TOO much signal (confirmed by a meter) and had to use an in-line attenuator.
If running any length underground, run cable made for that and put it in conduit.
To prevent against lighting strikes, a grounding block is a good idea where the cable enters the house.
Be careful not to stretch ANY run too tight, especially where it rounds a corner or edge and especially in unheated spaces subject to wide temperature swings. I have seen thermal expansion and contraction literally wear through the insulation and shielding from the motion where a cable rounded a brick chimney in an attic space. Yes, I did this myself and learned from it! I would connect the cable loosely to something on either side of the corner and allow plenty of slack in the bend.
If running cable through holes drilled in joists, be sure to follow the structural guidelines about making such holes. Also, I think the holes should either have enough extra space for a mouse to go through or be sealed. We had one experience where a mouse enlarged the hole by chewing and chewed through the cable as well. In that case it was a power cable which splattered his little brains inside the ceiling, but it could have been a video cable and the break would be very difficult to find and repair.
If this is new construction, I'd strongly consider putting cable in a good-sized plastic conduit or metal conduit for runs that would be inaccessible later (especially underground, say to a separate shop and down a the length of the house if there is no open access above or below). You can even run cable under concrete this way. I would not run AC power in the same conduit, but I always run a few extra wires for future use - will you ever need telephone, security system, intercom, ethernet, kid's monitor, etc.? If you include a length of strong nylon cord you can pull a new wire through the cable in the future. (pull another length of cord too!)
I hear you on the electrician thing. I always did my own electrical work, from changing out service entrances to wiring the circuits, inspected and otherwise. I figured that with a little research I could do at least as well as some of the yahoos I've seen in the business. I've had to fix foul ups by "professionals" in every house we've owned.
>I hear you all about quality splitters. Many many years ago, I had a cable guy out to diagnose a problem. The cause was traced back to a signal splitter purchased at Radio Shack. I'm not slamming RS....probably slamming myself as I'm sure I bought the cheapest one they had. At that time....(again...eons ago), a splitter was just a splitter.
So....where do you suggest I go to find a "good" splitter and what exactly should I look for?
As for a hub....same question(s)....where and what to look for.
TIA
Terry Alexander
PS: Brick guys are brining equipment tomorrow!
Jerry White
>Good advice so far. In addition to what has been mentioned above, you might consider running two coaxial cables to any location you might have a remote chance of wanting to install a PVR type cable/satellite receiver. Also, consider running a CAT5 cable to each location for future network interface.
Of course the conduit to each location suggested above would allow you to address those future needs easily enough as they occur.
>Hi Terry. When we built back in 2002, I installed Belden Home Automation Cable. Belden Inc. is one of the best companies in the cable business, and is available at most electronic parts houses. (Rat Shack does not count.)
The cable I installed is about 1" in diameter, and there is around 1500 ft. worth making runs all around the house and out to the shop area. Each room in the house as 3 outlets. Each outlet has 2 RG6 coax, 2 Cat-5 ether net, and a fiber optic run. All this 'wires' are in one BAC, Big xxx Cable. One end of each run terminates in a patch panel in a closet. The satellite cables are Belden Twin coax from the dish to the patch panel.
You may not want to go to this level but it is something to consider, especially if you plan to stay in your house a long time.
Just stay away from Radio shack, and the borgs for you coax. Repeat after me, Belden, Belden, Belden.
Good Luck,
Ken
>Don't really know about which is the best. All I know is that the one circuit city sold me has worked just fine for many years.
The comment below about running two coax cables to each box is very important. In order for your receiver box to record one channel while watching another it is necessary for the receiver to get imputs from two channels. This will require two coax cables.
GalenV
>If you do not know if you are going with cable TV or dish TV in either case you need to do what Chad suggest. Run seperate coax from one service location that will be where you put your hub to each location you want to have a possible TV. Then run a line to where you might put a dish and another where your normal utility service is, as it is where most cable will be run in. DO NOT run lines from room to room in series with splitters as you will degrade the signal.
Honeywell makes a hub for cable and units for dish. You have to decide. If you locate the hub say in a main floor closet you can also have one DVD player there that can feed to any one room. With the hub and seperate runs to each location you can have dish converter boxes at each set and watch different channals. That's were I think just cable works well as no boxes needed at each TV.
If you decide right away either your cable provider or dish provider will normally put in so many lines for free on hookup. Each could also tell you were they would run line into your home or locate dish.
I have found it is cheaper to have the cables installed then buy all the parts and insure you make good terminations on all the lines. If you know where you want everything and walls are open they can give you a good estimate of install price and that is better then deciding as they go.
>Hi Jason. I am not sure what you mean by terminations. To me a termination is the piece of equipment on the end of the coax. I don't count things like splitters or in line connectors. Any two-way splitter is a guaranteed loss of 1/2 the signal at each output terminal. If you go to a three way you get 1/2 on one terminal, and 1/4 on each of the other two, at least for the splitters I have seen for TV use. As Minton Friedman liked to say, there is no such thing as a free lunch.
If you are concerned with splices in the coax, the simple rule is don't do it if there is a way to avoid it.
An additional comment for Terry: don't about any inspections of your Video/audio cabling. It is considered "low voltage" and of no interest to electrical inspectors, at least it is that way in Texas.
Happy wiring,
Ken
I had two new cable tv lines put in about a year ago and they had to put in coaxial lightening surge suppressors that ground the shield. I was told it was to meet the National Electical Code that was also a part of the city electrical code. The old line had been run to close to the main power circuit breaker box which also was not up to code.
At least in Iowa they do cover cable connections and how they are run at least into the home. They did not say there as anything to be looked at beyond that except I know he kept lines away from any 120 volt Romex runs. I imagine there is something related to seperation distance of low voltage to 120 volt lines. UL panels built where I worked had to keep any signal and low voltage seperated from 120.
>I've been told by every cable installer that the best way to do it is to split the signal once--if you have 3 TVs and a broadband-connected computer, then you would have a 4-way splitter to serve each. And, yes, in-line splices are less than desirable. My point, though, is that even the best connector (what I mean by termination--termination of the cable, on either end) has some signal loss associated with it. The worse the connection, the more signal loss/leakage). I once called for service on my cable because I had ONE channel that had a little bit of a snowy overlay to the picture. I ended up canceling that service call when I discovered that the F-connector on the TV was about 1/16 of a turn loose--tightened it up and the signal was back to full strength.
There is a reason the crimp-style connectors are no longer used--too much signal loss for broadband (and DVR 2-way). The crimp brings the shielding too close to the center conductor. Hence the current use of compression/friction connections.
Jason
>Hi Jason. I totally agree that the crimp F-type connectors are junk. The crimping action will disrupt the characteristics of the cable. In addition, they may look easy to install, they can be(they are) a pain in the rear. However, I must admit that I used them in my configuration here and there, but at least I have a crimp tool that is supposed to do the crimping correctly.
Have a good weekend,
Ken
>4-5 years ago when I decided to hook back up to cable, I got ready for the installer. I went out and bought a kit with the compression/friction tool and several connectors, some bulk cable (yes, from a borg) and got all my interior cabling switched to RG6 from the RG59 I had hooked up to my omni-directional antenna. So the cable guy finally gets me all hooked up (had to use my self-feed auger bit at one point--he thought it was the bee's knees). Then he tells me that the local cable office gives away pre-made cable lengths in just about whatever length I would need. Arrrgh.
Jason
>John, you did what I probably would have done. My Dad used to say that there was 3 parts to a job: make ready, do, put away. I do pretty good on the make ready, fair to middling on the do, and no so good on the put away.
In the ham radio community they say that an omni-directional antenna works equally poorly in all directions. ;-)
Have fun,
Ken
