Differential finishing and pine - concerns?
Scott in Douglassville, PA
>Hi, all -
I'm close to gluing up the waist of the Dominy clock project. I'm debating on finishing the interior. If I do, I'll want to do that before gluing up.
The wood's old white pine, pretty knotty. The exterior of the clock is likely to get either a semi-transparent stain or (more likely) oil based paint. For the interior, all I want to do, if anything, is spray on Zinnser Bull's Eye shallac (which isn't dewaxed, I know - shouldn't be a problem, though). Here's the debate, though - for boards less than 10" wide, should I be concerned about cupping from differential finishing and uneven moisture absorption? I'd really rather leave the interior raw - smells nice and looks better.
Lemme hear it.
Thanks,
Scott
Re: Differential finishing and pine - concerns?
No problema either way
>Good Afternoon Scott,
I agree with Clint. The backs of the clock bonnet, waist, and base are small enough that differential finishing won't matter, as it might in more expansive panels.
George
