Re: OT cleaning inside of windshield.
Jim Pugh, Elyria, OH
>Today we had a little sunshine so I moved the van out of the garage, made a mixture of Dawn dish soap and hot water, got some good quality OOOO steel wool, put a large towel on the dash to protect from slop, and had a clean up towel ready to go. Wet a section with the soapy water and a rag, worked it over with the steel wool and wiped it off with a smaller towel. I won't say the windshield inside is totally clean but it is waaaaay cleaner than it has been in the past. Oh, and a note if someone else tries this.....you have to get everything wiped off while it is still wet or start over.
Ken: I did buy some Spot-X to use as an alternate but don't seem to need it. Will use it on some glass shower doors tho. Thanks for the suggestion.
Bill T: your suggestion that the coating on the window was a greasy substance got me to thinking in the right direction. Thanks. Oh, and it also explained why other attempts to remove it just smeared it around.
To John K. Jordan and others who suggested the steel wool - many thanks.
Re: Re: OT cleaning inside of windshield.
>Great! BTW, I always use the steel wool dry then wipe with a soft dry cloth or paper towel. That way it turns most anything on the surface into dust which falls away. If I use it wet, it smears and needs a lot more work. This probably wouldn't work if the surface had some kind of oil or grease.
GalenV
>Next Halloween I will remember to put the Vaseline on the inside of the car windows cause it sounds like it is harder to get off. :-)
Was good to hear you found a "solution"!
Gene Gauss
>The 0000 steel wool always worked for me with just plain Windex window cleaner. I think it's alcohol based, which will cut most oils.
