Tinting Epoxy
Tinting Epoxy
Tinting Epoxy
Doug Reynolds in Seattle
>Need to fill a few knot holes in cherry. Can I use Trans Tint dye to tint the epoxy or, does something else work better. Only need a little so, don't want to buy a whole can of universal tinting colorant or Japan colors if I don't need to.
I plan to use an oil finish and let the cherry age naturally. What color tint would you recommend?
Re: Tinting Epoxy
Bart Goldberg
Re: Tinting Epoxy
Bart Goldberg
>I usually add some sanding dust from my finish sander to the Epoxy. It is really hard to match the wood color, so I tend to make my repairs a bit darker than the surrounding wood. I like the effect.
My 2 cents
Bart
Re: Tinting Epoxy
Re: Tinting Epoxy
Joseph
>The few times I've had to color epoxy, I used a tiny bit of Varathane gel stain, and all went well.
Re: Tinting Epoxy
Re: Tinting Epoxy
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I am with Bart, in that I use the sanding dust out of my belt-sander. If it is from the same wood, it will usually come out darker than the surrounding wood when it is wet out with the epoxy.
If you mix it as thick as peanut butter, it will sand out without being too shiny, and look pretty natural.
Re: Tinting Epoxy
Re: Tinting Epoxy
>I've used a lot of different things to color epoxy. Stains work well, I've usually used minwax because that's what I have. I use shoe dye(the alcohol based) To fill knots I like to use the brown or black shoe dye but then I don't mix it so it is a solid color. I mix the epoxy and stir it, then I add the color and stir until it looks like it is streaked. I put this in the knots and the clear area picks up some of the color of the knot.
You can also add some sawdust at this stage but pick the dust that more closely resembles the knot. The standard sanding dust will usually be lighter. I take a knot (doesn't have to be from the same wood) over to the belt sander and just make my own dust to the color I want.
Re: Tinting Epoxy
Re: Tinting Epoxy *LINK*
Jim Dillon
>Doug,
Here is a link to a nice WC thread on September 8, 2008. A number of suggestions were made for tinting epoxy. While the object being filled, a pen, is different than what you are working on, the objective is the same. Hope this helps.
Jim
Epoxy tinting
