Where to buy VELCRO ?
Basil
>The pad on my ROS sander is worn out ...smooth as my butt... or smoother.... the sandpaper no longer sticks. I need a quick fix. Is there anywhere I can buy a kit or some raw pieces that can be cut to make a new pad for my ROS ? WAL-MART, K-MART, hobby store, anywhere?
Basil
Re: Where to buy VELCRO ?
Grant Wilkinson
>Would this do the trick?
http://www.leevalley.com/wood/page.aspx?c=1&p=20170&cat=1,42500
Greg
>You need the replacement pad made by the manufacturer of your sander. They all wear out eventually and they all sell replacements. I don't think you could get a home made pad to stick properly.
Depending on your model, some can be picked up right at Home Depot, Lowes, Woodcraft, etc.
Ray Carson - Lawrenceville, NJ
>Basil,
All the places you mentioned might have what your looking for. You also might want to try a local fabric store or a local seamstress. Also, do you have a Micheal's or A.C. Moore store near you? These are craft stores usually found in and around the Big Box stores. Micheal's is the chain store that seems to be common amongst these. I know they have Velcro.
Also, try Home Depot or Lowes if you have one near you. They have stuff like Velcro in the paint aisles and/or in the aisle with all the window replacement hardware.
Ray
Bill White
>Hobby Lobby.
Bill
Thanks.......Fixed and broke again.
Basil
>Never thought of Home-Depot having them but they did.....bought one and I am now headed back for another one ......or two.
Making massive table legs from old red cedar logs. I have to bare down on the sander to get in the cracks, log irregularities and around the knots from limbs. That much down pressure on the sander for a few minutes and the hook/loop attachment is shot.
Now I got to make a jig so I can chuck them up in the sawmill to get them cut flat on the ends and the same length.
Basil
Sounds like a cool project...
John E in SC
>Please post pics when you're done - would love to see it.
John
Leave it smooth and use
Dustmaker Mike
>PSA sandpaper until you are done. Just an idea.
Re: Leave it smooth and use
jared
>I replaced the velcro on some of the sanding pads I use on bowls. I got some strips of self adhesive velcro either from walmart or a fabric store. It was supposed to be self adhesive but I mixed up some epoxy and glued it on. I sanded the remaining velcro on the pads off on my belt sander before I glued the new strips on. I had to use two or three strips side by side to get big enough pads. The pads get really hot when I sand bowls but it has held up a long time. I was afraid the glue would get hot and give away but so far that hasnt happened. Jared
Time for hand approach?
Bill Houghton, sunny in Sebastopol, CA
>Would it work to use sandpaper as a hand tool? Sounds like you're running into a lot of problems trying to get a tool designed mainly for flat work to work on highly irregular work. Maybe some cloth-backed paper ripped into appropriately sized and shaped strips would ultimately be faster, even if it seems slower at first.
Re: Time for hand approach?
Glenn Madsen
>Klingspor's sells 'value boxes' of sanding medium, in rolls, essentially end cuts from their commercial businesses. And they are CHEAP!
A wide array of grits, backings, etc. in a large box is like $10 or $20. I bought some three or four years ago, and have hardly made a dent in it. The boxes sit behind my lathe, and I never sand with old paper any more...
Balance and Proportion
>Good Evening Glenn,
I generally buy one of the $20 boxes every 12 months and cut the stuff into smaller sizes to fit my orbital and detail sanders. The rolls are handy in the lathe room. I also order psa and velcro discs for the ROSanders. Not withstanding SWMBO's assertions, I do not spend more money on sandpaper than I do on cold beer. After all, a man must remain true to his principles while keeping balance and proportion in his life.
George
Where do you find the "value-boxes"?
Chad Pearson
Verbal description of what I'm doing.
Basil
>Fellow has an old horse shoe shaped table top. It's about 6'X 6', open in the middle...... picture an 18" or so wide, 4" thick board of heart pine in the shape of a horse shoe. It at one time had 3 legs on it.....I'm making legs for it and I'm going to refinsh the top.
This table is going in his 10,000 sq. ft. barn/shop/2,000 sq. ft. appartment. He's going to use it for a dining/gambling/bar table while building his house.
Maybe if I do well, he'll let me live in the barn/shop/appartment when he gets the house built......LOL
Thanks again for all ya'lls sugestions but a pocket knife, belt sander and ROS is the way to go on this job.
Basil
Re: Verbal description of what I'm doing.
George Koch
>Basil, whenever the pad on my ros wore out in the middle of a project, for a temporary fix, I would use the spray contact cement on the hook and loop disks to adhere them to the worn out pad. Always worked fine for me. George
Re: Where do you find the "value-boxes"?
Glenn Madsen near San Francisco
>http://www.woodworkingshop.com/cgi-bin/F2C645E2/mac/subgrp.mac/subGroupSelection?lenGrpDsc=4BBOXBARGAIN%20BOX%20-%20ALL%20TYPES
Watch the wrap...
on Henthorn
>Some of the supply catalogs have inexpensive kits with enough heavy duty velcro to repair several disks, A repair lasted me for a long time. I think I bought the kit from Woodworkers Supply but other catalogs also has the kits. I no longer have or get catalogs so I can't point to ne specifically.
