a compressed air piping question
Quebecnewf
>I have approx 50 feet of galv pipe 10 ft lengths 1 1/2" dia. and another 50 feet of galv pipe of 1" dia. My plan is to run this around the walls of the shop just below the toplate and then drop lines down the walls using tees from this at 10 ft intervals . I figure the pipe is free and will give me about the same as another tank of 10 gal tank full of compresed air . Is there any reason that this would not be a good way to go. Condensation problems ETc ETC ?
Quebecnewf
Re: a compressed air piping question
Ronald------WebKitFormBoundaryAA5MAAC+AAX9AALx
>Run it on a slant and put a pitcock in to drain water off. Sounds good to me.
Rick L
Rick L
>Run it at a slant so it drains into the tank of the compressor and make sure the T's go up then down. Keeps the water from settling into the drops and is the standard way to do drops.
GalenV
>Seems like your fitting and reducer cost would add up unless you have them as well. Then there is the hangers for larger pipe. I cannot thread larger pipe but maybe you have the tooling.
I'd sell the larger pipe and stick with smaller. You still have moisture collection but everything is easy to work with.
Just never use PVC for air!
