Re: Miter "clamps" using packing tape
John E in SC
>Doubt that would work very well. BP cuffs don't apply pressure evenly. They have a bladder that inflates, and it doesn't go all the way around. If you like next time you get your BP checked, there is usually an arrow on the cuff used to locate over the brachial artery, which is where you want the pressure concentrated.
Nice thought thought though. I have seen (and used) a similar concept back when I was growing up. My Dad used to run a service station, and my teenage years were spent changing tires. We used to have what looked like a fire hose with a valve stem on it that you could fasten around the middle of a tire that wouldn't seal to a rim, and then when you inflated the hose, it would squeeze the tire to make the bead seal better with the rim. A similar concept (where the "bladder" goes all the way around could probably clamp round, or nearly round, objects fairly well.
