Cabinet construction w/ prefinished plywood
Chad Pearson
>I am about to build new cherry cabinets for my kitchen. I would like to use prefinished maple plywood to keep the interiors bright. I would like the exteriors to be cherry. This is no problem for the front of the cabinet because of the faceframe and door. However, in my layout there will be some exposed sides and backs.
I saw that the local blue borg carried cabinets that appeared to have been made from a plywood with maple on the interior and cherry on the exterior. It does not appear that my local suppliers carry anything like this.
I am curious to know how others would handle this problem. Would you simply tack on some 1/4 inch cherry plywood on the exposed pieces or would you attempt to veneer a sheet of cherry on top of the maple? It seems like either method may create problems with the plywood becoming "unbalanced" when attached/glued.
