workbench designs
workbench designs
workbench designs
Mark Webster
>I'm looking for input and possible design ideas for a workbench that I can build that can also double as an outfeed table for my table saw.
Re: workbench designs
Ralph Turney
>I built the one from Woodsmith issue number 50 (not #66) about 15 years ago and if I had it to do again the only thing I would change is that I would have made it bigger. But at the time my space was limited and I didn't know any better. All in all, it's been a great bench that's holding up like new and with the tool area that's built into the lower area, it weights a ton and even planing table tops on it, it has NEVER even budged. Of course there are a million variations on even your basic workbench, but I don't think you can go wrong basing one on that design.
Joseph Mulherin, Sr
>Mark, Popular Woodworking.com has online three benches you can purchase plans for that will fit your need
>I think any basic workbench should work for you - you just have to have the right height. Scott Landis has an excellent workbench book titled "The Workbench Book". It is entertaining reading. You can get lots of ideas out of it and plan or adapt a bench that is suited to you.
Robert R Clough - Thorncraft
>And you should look at Chris Schwarz's book "From Design & Theory to Construction and Use". Pop WW has it.
I just built a fifth one about two months ago
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>And several of them are in use as outfeed tables, so here is a little bit to consider.
First, without knowing how tall you are. Figure out how high you want the bench. You can make a little platform to lift the saw up if you need it higher.
I like my bench at 36", so my saws are up on platforms about two inches high.
Also, I make the platform tilted a little, so that a straight line level off of the saw table hits in the middle of the bench, while the front edge is about 3/8" lower than the TS top. This clears the grooves of the TS slots for sleds and gauge.It also helps when ripping thin stock like laminates, and veneers that sag on the outfeed, yet supports long stock by the time they would sag when longer and thicker. I leave a gap between the TS and my bench of about 2". Good for clamping, cross-cutting with a circular saw etc.
I always leave a long overhang on the far end, to have a vise on that end. As well as the sides for clamping, and the other end as well. If you use a thin top that needs a frame, leave it well back to allow clamping work to the top with easy clamps like spring clamps for easy jobs like sanding and routing.
On this last one, and the one that I use with my job-site saw, have thick tops. There is NOT any apron frame. The stiff top doesn't need it. The rails under the tool shelf is M&T into the legs, with the short rails above the long rails. With this arrangement, I put two drawers under the tool shelf which pull out from the ends.
I have a few screws angled up from the top of each leg into the top, which is easily removed. And even though I haven't done it yet, I will hang a drawer or two under the top of this one.
I put a strip outlet on each end, so the tools are always plugged in, while resting on the shelf, and easily reach all of the top.
On the bottom of the legs on the vise end, I have casters which are screwed into a bevel on the side which allows it to touch the floor off from the end. When I lift the other end, the legs are all clear of the floor, for easily wheeling it around the shop, or job-site.
Are you crowded for space with your situation? While it is great to have a nice bench as an outfeed table, it is also a terrible waste of time, in that your project is always in the way of using the TS. Once you go there, it is like a bad addiction, it is a hard habit to break.
Fred Davis
>look at shopshot #876
FredD
