Bending padouk veneer
Dan Mitchell
>I bought a piece of padouk to make a base for a pottery lamp my wife has made. Since most of the wood will not be seen (as it's under the lamp) I decided to try cutting some veneer strips to apply to MDF, rather than using all this beautiful wood & have it hidden. Below is a pic of the veneer I cut on the band saw & the MDF disk. The strips are ~3/64" thick, the disk is 9.25" in diameter & about 3/4" high. Applying the top part is pretty obvious, but I'm wondering the best way to apply the band around the circumference of the disk. It seems as though the wood will bend to a circle that size, but it takes a fair amount of force to get it to do so, & I wouldn't be surprised if it snapped at some point. Should I soak it in water 1st? I've read about steaming, but I don't know how I'd accomplish that. Also, if the wood is wet from soaking, how does this affect the gluing process & the MDF? What's the best clamping method for this process? I'm thinking of either using a band clamp (I have one of those Bessey framing clamps), or a ratcheting cargo strap I have.
TIA
Dan
