Shrinking Lumber
Shrinking Lumber
Shrinking Lumber
Ken Krawford
>I went to my local lumber yard this morning to get some 1/4" MDF to use for panels in some cope and stick doors I am making. I had just bought a new bit to cope the doors and was delighted with the results. I was dismayed when the lumber yard informed me that no one carries MDF (or little else for that matter) that is a full 1/4" thick. I ended up buying baltic birch plywood (at $36 for a 5x5 sheet).
What are people using for flat panels in doors anymore? I considered shimming the undersized stock but decided against it.
Re: Shrinking Lumber
Hank Knight
>My house was built in 1934. I was in the crawl space several weeks ago and noticed the floor joists were HUGE. Actually they were 2 X 10s and actually measured 2" by 10" and the cross braces were really 2" by 4". Next to today's 2 x 10s and 2 X 4s it looked odd.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I don't know where you are, but there is no problem getting it in Arkansas.
Jim DeLaney, Austintown, Ohio
>Nearly every yard around here has quarter, half, and three-quarter inch MD, and it really is those thicknesses. Even my local Home Depot has it.
Also, all the baltic birch that I've ever seen has been metric: Quarter inch is 6mm, half inch is 12mm, and three-quarter is 18mm. Check yours to see if that isn't what you've really got.
Jim D.
>Back in the '70s I would buy rough lumber from small sawmills and air dry. (I still have some of the walnut, think it's dry yet? :) One sawyer told me the lumber industry at the time was trying to get the standards changed so finished 2" lumber was no longer 1.5" but 1.25" (if I remember correctly). I was aghast. This is far past the justification of sawing for normal planing loss but would let sawmills cut smaller to get more yield from a log and make more money without raising the cost per "board foot". This is an insane idea, driven by the profit motive, and easily dismissed by simply adjusting the price of existing lumber as needed. Fortunately, nothing ever came of it.
I saw my own lumber these days and yes, I really like full 2" boards for barn and outbuilding construction and mods. I can still plane for indoor use if needed but I usually use it rough.
pecker
>In the future, it may be better to obtain your stock first, then buy the cutters that fit it. I have seen rails and stile bits that come with a slot cutter for .22" as well as .20"
The last mahogany ply I bought was .199"
Amana Adjustable Bits
Joe in Tallahassee FLA
>Check out the Amana Instile and Rail router bits. They are adjustable with shims to match various plywood thicknesses. I have a set and they are nice.
I recently made a set of cypress cabinets using cypress ply panels. I had to order the plywood in two orders about a month apart. The first batch was thinner than the second. I was able to adjust the bits and thus had no prob.
http://www.amanatool.com/bits-fv/55433.html#
Joe
