Re: New House construction - Insulation question
Grant in Iowa
>Terry,
It depends laregely on where the house is being built, and the type of construction to be used. In most areas, you can use fiberglas insulation just fine if you also do the following:
One of the big things that is often overlooked is caulking the framing before the siding goes on. In a house with a basement, the typical construction utilizes a rim joist around the outside of the floor joists. This rim joist is one of the leading causes of air leaks in the home envelope. When the framing was done on our house, we caulked the outside of the rim joist before they sheathed it, and also caulked all accessable joints on the inside of the rim joist as well before the basement was insulated.
Other areas to caulk are where the wiring and other mechanicals pass from a heated space to an unheated space (such as at the tops of walls, around vent ducting, exterior lighting boxes, exterior wall outlets (even the ones facing inward), etc. Once the wiring is roughed in, you can caulk the holes in the boxes where the wiring enters. I see many homes that on a cold day you can feel air around the outlets, which is preventable if you caulk and housewrap correctly. We also installed a vapor barrier on all exterior walls over the insulation, running a bead of caulk around the top plate before installing the vapor barrier. The only holes in the walls for air infiltration then are wherever outlet boxes occur in exterior walls, which we sealed as described above.
One year in the new house (an 1800 square foot ranch with a finished basement, bringing total finished square footage to about 3200), and we have a decent idea of our heating bill:
Above house with forced air natural gas heat, a natural gas dryer and water heater, and 4 adults living there showering and laundry etc. 6" exterior walls and R-38+ in the attic. I also heat my 1400 square foot shop to above freezing all winter(and to 60 degrees when I was in there). Our high gas bill was $180 in Iowa during the depths of winter last year. It never got above about 25 degrees F. in that entire month with many nights below zero F. Contrast that against the average summer gas bill of $35 or so to determine the actual cost of heating both the house and shop. Not bad compared to others I have talked to and way better than my old house, which sometimes hit $300. I did augment my gas heat with a woodburning fireplace, but only a day or so a week.
People were trying to twist our arms into ground source/ geothermal for a large extra cost. It didn't make sense when I crunched the numbers and considered the fact that I was borrowing the money. So, we spent our own time to insulate things carefully and well, and it seems to have paid off.
Note that the techniques we use are good for our region, but your region and climate may dictate other methods.
Regards,
Grant in Iowa
