OT Small DTVs
Mike Farinella
>We have a small TV in the kitchen (9") we would like to replace with a digital one. It is perfect for the location. I have Googled "small DTVs" and guess what?... there aren't any. What am I missing here?
OT Small DTVs
Mike Farinella
Re: OT Small DTVs *LINK*
Ned Bulken
>smallest I've found is a 16" toshiba at tigerdirect
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3818
Re: not toshiba, still smallest
Ned Bulken
Michael J Bitetti
>The "D" simply means a digital signal. The last TV I had before my current one was actually a digital but with CRT and with 223lbs of glass up front.
You are most likely looking for a flat panel of which the LCD is most common.
The link I pasted below is for an under-counter mount, drop down type and even has a DVD player in it.
Remember, early next year you'll need a digital tuner to recieve via your antenna, a standard convertor box for cable and/or if you have satellite.
Hope this helps
Mike
http://mcmelectronics.com/product/58-10795
