out of square - plywood back
Bob in Green Bay
>Thanks all for suggestions regarding the solution to fix squaring up a case.
I will proceed with putting a baltic birch plywood back on the solid cherry case. I have some 1/4" in my shop to use.
One question I am wrestling with is:
Do I rabbet the back edge and bottom shelf to accept this back to it is not viewed from the side? I am thinking so but another step I did not account for. If so how deep to the outside edge? My sides are 3/4" thick. Tempting just to glue and screw to the back at the time of glue up, but that seem like the easy way out, not in the spirit of true craftsmanship.
The rabbet solution keeps the view of "not cherry" to the back only, which is not a big deal. I am thinking this may also add to rigidness of the case.
Bob in Green Bay - snowing right now - the green is dissappearing in the grass
Re: out of square - plywood back
Jesper, Denmark
Jesper, Denmark
>Slots or grooves in the sides, tops and bottom are the "right" way to do it. They should only be about 1/4 inch deep and 1/4 inch from the edge. Don't glue in - the glue is not necessary. Trim the ply jso it just fits, but does not bind in the slots.
John McGaw
>If your case was built with what most folks would call "normal" construction techniques then a solid plywood back will definitely take care of any racking problems and preserve the existing joints. There are ways beyond solid backs to take care of the problem but they surely are more difficult to add after the fact.
Making the rabbet about half the width of the stock the plywood is being let into is usually fine although going to 2/3rds is good too and makes tacking the back in place less troublesome. Depth, of course, will depend on then thickness of the plywood.
rabbit, nail and glue
Bill Tindall, E.TN
>3/8 x a bit more than 1/4" deep rabbit. Nail and glue (very sparing on the glue, use a brush to apply a thin layer). You can glue because its plywood.
I didn't say this before, but this case needs the back for strength and rigidity. I think you would have found that a dado without a shoulder would have provided little rigidity and the case would have failed in time.
