Re: OT cleaning inside of windshield
ken raddon
>I owned a window cleaning business for 25 years and if what you have used did not cut it then I would have to think it is "in" not "on" the glass.
Something has chemically altered the surface of the glass. We call that "hazing.' There is a product that is easily aquired that will work on some types of hazing.
Get some "Spot X" at home depot in the cleaning isle. It's in a small yellow bottle with a red cap. It is a powder and is a pumice that is eitherr soft enough or fine enough that it will not scratch glass. It is used to get off hardwater stains. It works really well on sticky residue from stickers or tape too.
Park the car where you can get plenty of light but no direct sunlight. That goes for whatever you're going to use. Work in sections until you find something that works. I mean don't do the entire window with everything you're going to try.
With that said here is the easiest way to tell if it will ever come off: wet a small area and scrape it with a single edge razor blade. If the razor blade removes some of the junk then you need only find an easier way to get it off. If the razor won't remove anything then it is in the glass not on it.
Ken Raddon.
