More Tall clock questions...
Scott in Douglassville, PA
>Egad - my engineering skills are rusty...
Ok, thinking out loud, and trying to plan ahead: The back of the case will extend to the top of the waist. The bonnet case is a top and two sides - Norm's plan relies on the one-piece waist/bonnet back for completing the bonnet. I think my design will be that the bonnet will slide on from the front the same way Norm's does, overhang the back of the clock by about 1/2", and a thin panel will slide up from the bottom of the back of the bonnet and be secured with a screw.
The main issue is that the clockworks need to be easily accessible on first installation of the case - after the clock is leveled, you need to adjust the beat rate with the pendulum, and match it with the works. Then every couple years, the works need cleaning and lubing. Which'll be my job, but that'll be fine. Anyway, the back panel will slide out after removing the one screw, and the bonnet can slide off the front to reveal the works. I think.
Next design change will be mounting the works. It needs to be independent of the dial board, which needs to be removable. I think the dial board will screw down like Norm's does, but will go into place after adjusting the works, which will be mounted to a separate board screwed to a cleat spanning the top of the waist.
Sound right?
Scott, pondering horology
