Tall clock design II - Back style?
Scott in Douglassville, PA
>Hi, all -
Ok, round II - I have the waist put together, but I need to decide on a back for the clock. Norm specs a sheet of 1/2" plywood (shocker). I'd like something a little more appropriate. Again, this is special wood to the inlaws - I'd like to use it for the back, so they can open the case and see the pine with nothing but shellac on it. I think that leaves me two choices for a 10" wide eastern white pine back - shiplapping, or frame and panel.
What say you folks? Shiplapping will require some additional engineering to the back for attaching the boards. Frame and panel will require a thin system (1/2" thick or less).
Re: Tall clock design II - Back style?
Simple panel
>Scott, I'd run grooves around the inside of the case and put a corresponding tongue all around your pine board. Make sure to face the rabbet on the back panel to the rear of the case so you can't see into the space from the front.
Good idea!
>I joined the sides to the front with a tongue and groove joint, so I'm already set up for it. Thanks for the idea, Ellis.
Leave expansion room
>Don't forget to leave a little expansion space between the rabbet and the groove, but only on the vertical edges.
