out of square
Bob in Green Bay
>I am building a TV stand that is essentially a box, more of a giant night stand really.
All is well, but now that I am in the preglue and drill stage, I can't quite achieve squareness. Its racked out of square by about 1/4" (checking for square bottom to top) which is enough to make me want to solve it since at a later time I will put front doors on it.
Basic construction is two sides about 17" wide and 28" tall. There is a dado in each side about 3" up from the bottom to receive the solid bottom - that is 36" across. I am using 1 1/4" stringers across the top at front and back that will be screwed, and plugged. A solid top will be affixed with cleats for more support.
Once flaw I will admit is that I used a cheap "wobbler" to cut the dado. Boy I hate that thing. The bottom and sides did not meet my expectation. I cleaned it up with a chisel best I could but in the end, hand planed down the thickness a bit(only at the ends) of the insert that goes into the dado to optimize the fit as it was a little tight. I fear this is where the problem lies but can not prove it to myself. I am thinking I could use one of those nice little router planes, but I am tooled up for the year.
Dimensions across the top and bottom measure the same by 1/32" and that is close enough I believe, just out of square at preglue
Any ideas to help me get this thing put together this weekend is greatly appreciated.
Bob in Green Bay - snow pending next week
