Re: Dan, 2 questions...
Dan Mitchell
>Stuart - I'd be very flattered if anyone wants to copy the design, that's why I posted it! ;-)
Here's another pic & the basics of construction. I found this caliper such a nice tool, especially for 10 bucks, I also bought one for regular use. Note that $9.99 is the online price, however I have found with Harbor Freight that if you print out any online price & bring it into a retail store, they will match it.
1) Remove the gray thread pitch sticker from the back of the caliper & remove the small screws.
2) Remove the steel back & depth rod. There's a small flat spring & a couple of brass shims inside, but it's all pretty obvious once you have it apart.
3) Cut the steel bits as illustrated by the black lines in the image. Exact size isn't too critical, I'm sure you get the idea from the pics.
4) The stainless steel used is very, very hard. Went through 3 bi-metal hand hacksaw blades cutting it, and when I went to drill the holes for the screws in the "foot" part (see image) which comes off the column, I had to heat the piece to red hot with a torch to lower the temper in order for my HSS bits to make an impression in it. The portion of the steel near where the depth rod is welded on (where the other 2 holes are drilled) is a bit softer, presumably from the heat applied when the rod was welded in place nearby.
5) I cut the grooves in the oak portion which holds the foot to the gauge and through which the 4 screws pass on the bandsaw, by positioning the fence ~1/16" from the blade, making a cut to the desired depth, then flipping the piece over & repeating, after which I carefully ate away the middle piece which remained. I then cut a thin strip on the bandsaw to glue on the top of this to cover the grooves.
6) The base is 2 pieces of ~.75" oak held with 3 drywall screws. Make the groove which clamps the column slightly narrower than the column itself, in order to provide a tight clamping action.
I hope this is helpful, if anyone has any additional questions, please don't hesitate to ask.
Dan
