repair crack in finished project?
Ken Platt (Granby, CT)
>Folks -
I'm just about done - or I thought I was - with my daughter's bed. I had put it together yesterday in the shop in order to check the fit of the rails to the foot and headboard.
Today, as I was fiddling with it (the rails aren't as snug to the head/foot posts as I'd like) I noticed that one rail had cracked, see the pic. The rail was all one piece, that is, not a glueup. There is a cleat on the inside to sit the boards which will support the mattress.
I'm guessing that either the screws for the cleat or the lower screw of the bed hardware created a weak spot, or maybe some residual internal stresses letting go? THe shiny thing to the right in the pic is the loswer hook of the bed hardware.
Anyhow, how would you go about fixing this? My thoughts are to put some regular yellow glue into the crack with a syringe and needle (to get it as far in as possible, then clamp (it closes up nicely when I tried clamping it dry).
I'm sure that'll hold for awhile....but I'm wondering if I should add in a screw from the bottom of the rail, where it wouldn't be seen. Or is there some other way? Or, should I just glue and see what happens?
This has been one of those projects where so many things have gone wrong that I'm wondering if the tree was the home of a spirit that has cursed me, kind of like those movies where someone opens the wrong tomb.....
Thanks -
Ken
Re: repair crack in finished project?
I would glue it as you suggest.
Lee Schierer - McKean, PA
>If the crack goes all the way through you can use dental floss to pull glue into the crack. PVA glue doesn't go through a syringe with a small needle very well and thinning it isn't recommended. Put the glue in, clamp it up, let it dry and touch up the finish. It sould be nearly invisible when you are done.
Lee
al heath
>your method sounds good...that is how I would fix it. I have also used gorilla glue, and forced it into cracks, let it dry, then scraped off the foam and fixed the finish afterward.
>Good Afternoon Ken,
My first choice is titebond and dentil floss as Lee suggests, although Al's choice of a poly glue would work also. I'd try to spread the crack slightly wider and insure complete glue coverage over the entire length. Then clamp, and clean off the squeeze out. I'd shy away from using a screw to pull it together/reinforce the repair. The glue will suffice. Adding another screw where you already have cleat fasteners and bed hardware will only make the area weaker. You will be gluing long grain to long grain=strong joint.
George
and also....
>BTW, Colonel, one of the many disasters with this project is that my wife let go as I was assembling it yesterday, so besides that crack I have a couple dings to repair also now. I consoled myself with remembering your infinitely-worse project fall. I still cringe when I think of your post on that....
Ken
Thanks, and...
>The dental floss is an excellent idea. I actually had not noticed if the crack went all the way through So I just ran down and looked, and on the inside the cleat is covering the crack for nearly it's entire length. So I guess I'll just have to work the glue in as best I can.
Ken
Yeah Ken--I Sure Got "Clocked" On That One!...
Is The Cleat Glued On? .
>Heyt Ken,
If the cleat is not glued, remove it and then address the split thoroughly as outlined above. Then reapply the cleat, using screws thru the same holes, and glue.
George
Dick Coers------WebKitFormBoundaryv54aV+RmMmGf6euZ
>When I need to get glue all the way through a crack, I put the glue on the top surface and put a shop vac nozzle up against the crack on the back side. With the vac on it will only take a second or two for the glue to show up on the back side. Clamp and wipe off the excess.
Bart Goldberg
Bart Goldberg
>I like the suggestion for re-gluing - but I would highly recommend using 2 part epoxy - it will flow into he crack if warmed up a bit and there is nothing stronger.
My 2 Cents
Bart
Yup, glued..oh well...
Thin epoxy?
>I love epoxy...I'll try sticking just about anything together with it. But I always seem to make a mess of the stuff, and if I have any more of this project to refinish, I just won't be able to hang on to my remaining shreds of sanity.
I vaguely recall hearing about a very thin - like water - type of epoxy that could flow easily into a crack. Every heard of this?
Ken
>Yet another great tip! Thanks -
Ken
>You can also blow it in with an air nozzle. (Infinitely messier, but sometimes effective.)
And you can flood the joint with glue and then use your fingers or a clamp to open and close it a few times to squeeze the glue into all the recesses. Adding more glue if necessary.
NOW he tells me...
>Barry, yet another great idea...read about an hour after I glued the dang thing. It never occurred to me to try the compressed air, too bad, as it would have been just the ticket for this crack.
I worked in as much glue as I could with some long needles. I was pressing the plunger on the syringe so hard the glue was working it's way around the plunger and up the barrel, but it was coming out the needle too. The 20 gauge needle worked great, but the 25 gauge was what really got the glue into the smaller parts of the crack. Then I used a 3 inch long stylet to work the glue even deeper, then clamped and unclamped a few times to move it around. I guess time will tell.
Ken
