I will sharpen them occasionally.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>In fact, I did a pair for my portable 12.5" planer this week. I am making some small drawers, using QS sycamore, some of which had a good bit of grain change. While the blades that were on it were not dull, they were tearing out the grain.
I had never put a face bevel on the knives for this small planer, but decided to give it a try for this project, and I am happy to report that they did just fine.
I have a couple of the 2 x 6" diamond hones with the heavy nickel plate, which I glued a wooden handle onto, that I used to honed a small ~ 10� bevel on the face of the cutting edge. It was actually easier to sharpen this small face bevel, than to have done the whole top bevel, before getting a sharp edge.
This is the first time that I have done it this way. I usually sharpen planer or jointer knives on my table saw, with a fixture running across table, using a 1/4" wide white wheel on the blade arbor, and a Koolmist unit spraying coolant right into the grind, while I slide the blades back and fourth across the jig.
This is an easy inexpensive way to keep your blades sharp.
