Joinery Question
Joinery Question
Joinery Question
Doug Reynolds in Seattle
>In making the chest for my daughter, see post below on knobs, my design is for the side to run all the way to the floor with nice cut-outs for feet. Sort of a very simple Shaker design. The top will be dovetailed to the sides with no molding or other ornamentation. Question is what do I do for the chest bottom? All the drawer dividers will be sliding dovetails let into each side and, runners mortised and tenoned and glued into the divider and nailed to the rear of the case side. Will this work as well for the case bottom if I make it a "dust panel" with a rear "divider" also dovetailed into the case sides and the drawer runners glued only to the front divider and the tenon in the rear sort of oversized and not glued at all to allow for wood movement?
Re: Joinery Question
Addendum
>She did not want ogee bracket feet or anything like that which sure would have made it easier on me as I could have made a separate base.
yes
Bill Tindall, E.TN
>or put a sliding dovetail bottom in of secondary wood with a narrow facing strip of primary wood. This latter arrangement will be quicker to do. Just did it on a cabinet which I will post soon. If you make half tails the joint is vastly easier to fit- just plane some off the flat side if the joint is too tight.
