>I have to replace my front porch stairs and would really like to make the open up as a curve rather than just straight out. I have 2 questions. I haven't put a lot of thought into this yet so I'm asking how you would make the rails, specifically what type of joints to use to prevent splitting later on. Second, should I make the bottom board curved (which would take much more lumber or require glue joints that will eventually fail) or should I make it angular like the bottom drawing. The bottom one would obviously be easier and less expensive but I have the woodworking skills to do just about anything.
I didn't draw this to scale. The steps are about 38" at the top so the bottom would only be about 5 to 6 feet wide, and about 6 steps.
The 4" wide horizontal curved hand railings on my deck (not built by me) were cut out of 2x6 pressure treated lumber in short 4' sections. If I had built it I would have used longer sections even if I had to cut them from 2x12s. The 2-by horizontal support pieces both under the hand rail and near the bottom (that provide rigidity and a place to fasten verticals) are curved 8' sections, laminated in four layers resawn from thicker stock. These appear to be nailed with no glue, but there could be waterproof construction adhesive between the layers. For a long curve, the thin pieces could be overlapped for higher strength.
Note that curving these pieces out while dropping in elevation will provide some "interesting" challenges - they will have to twist slightly to keep the sides vertical for fastening the balusters. You will have the same issue with the hand railing itself unless the edges are milled vertical, but since the rails are relatively thin, non-vertical edges at the ends may not be too objectionable.
If you curve the railing but have angular supports it seems you would have a problem where the two joined unless the railing was very wide. I can imagine a railing made entirely of angular segments that would look great and probably be easier to construct.
BTW, when I build railings I try to avoid butt joints, either angled or straight, since they will ALWAYS look sloppy as the lumber ages and warps. But where it is necessary, I chisel out space underneath and join the two with a steel plate held with screws. Other options might be to mill finger joints in the ends or rout a slot and glue in splines. However, I've learned that fine joinery on new (wet) pressure treated lumber is a losing battle.
>All kinds of possibilities for Code conflicts here. If you are going to have this inspected, you might want to talk it over with your local code office first.
I lamianted treated lumber in curves, making my own glue-lam beams. Used 3M 5200 (I think). Came in caulking tubes and looked like white caulk. It worked well, but the cure time for it was a week. So I made a beam each weekend for a month.
You can make wide curved treads out of straight pieces by sawing the curve down the middle of a wide board and then switching the position of the two pieces, gluing the straight edges together.
>I'd love to build it out of IPE but it would be more expensive than my house. I live in a group of houses that were thrown together about as cheap as you get.
I'm not sure if you want to use alternative materials, but I think Trex would accommodate these kinds of curves easily. You would need to build a good solid sub-structure, but once you got that done, the Trex would bend around these curves, and would be maintenance free to boot!
The only real downside to Trex is the cost. But it's been around long enough that you could call around to suppliers to see if they had any of the older, discontinued colors or styles that they might clearance out to you.
I did a huge deck and two long sets of stairs with Trex, and it really is pretty good to work with.
