Bending wood
Bending wood
Bending wood
Xeon
>Hi,
I'm looking for someone to provide me with pieces of bended wood like this: http://www.woodcentral.com/cgi-bin/messages3.pl?read=370728
If anyone can assist, that would be great! I need about 15 - 20 pieces.
Thanks,
Xeon
Re: Bending wood
A llittle more advice on this....
>Xeon, I think you may be confusing things here. That earlier discussion was about plywood, which is generally pretty flat, although the .2"-thick 5-ply birch you settled on will probably have a bit of warp and twist. If you want something flatter, you should be looking at regular 1/2" (actually nominally 10mm) Baltic birch or even thicker Apple-ply. One possible advantage of the thin stuff that you described is that your press will flatten it nicely as you're transferring the image.
One other thing: Assuming one of our folks accommodates your order, I would suggest that someone, either they or you, sand the printing surface of the plywood squares to at least 220-grit, and probably even finer, to give you a clean, smooth surface to print on. I think it will make a big difference in the image quality. And I'd experiment with my earlier suggestion of hitting the surface with matte spray prior to sanding. That might help, too.
Anybody here able to help Xeon out?
Re: Bending wood
Re: Bending wood
>Do you want plywood that you can print then bend? Or do you want something more solid? If you go with 1/8" plywood (nominal 0.125") that runs about $13 a sheet, 1/4" runs about $35, 3/8" runs about $48 and 1/2" runs about $70. (All these are approximate prices from a price sheet from last year.) So if you are talking about 20 pieces at 4" x 4", you can get all of them out of one sheet. Drop me an email and we can talk.
Re: Bending wood
Re: Bending wood
Fred Davis
>Then there is bending plywood made for the purpose of bending.
FredD
