Re: OT Antenna amplifier?
Curly Smith
>I'll echo what John said. Go to the Antenna Web site, find the stations in your area and make sure that your antenna is properly oriented. Check the orientation with the signal strength meter that's part of the converter box. Then remove all splitters from the line and recheck the signal strength. If the signal strength improves dramatically then you likely need an amplifier installed ahead of any needed splitters. Note that you should only install the splitters that will be used, you shouldn't run the signal to rooms where it won't be used because each splitter degrades the signal.
I did the above and ended up installing a Winegard AP-8700 Antenna Amplifier. However, before installing the amplifier, I replaced the existing medium-range antenna with a spare long-range antenna that the previous owner had installed and ended up with dreadful reception - the long range antenna was simply too much antenna. If you have good reception with your existing antenna then you're likely better off spending money on an amplifier than on a stronger antenna.
