Veritas - Innovation in Tools
oak stairs
oak stairs
oak stairs
Steve Silca
>Well I posted this picture a few days ago with an inquiry about a removeable railing. Thanks for the input - it helped out a lot.
Now, thanks to some advice on this forum, I've decided against using tile for the stair treads because it could be slippery.
I'm going with an all-oak staircase - railing treads, and risers. I might use 1/4" plywood for the risers, or it may be 3/4" solid. My question is about the treads. I know they have standard oak treads at the home centers that are over 1" thick. However, those won't help me on these stairs because most of the treads are triangle shaped. I do have access to a whole bunch of 3/4" solid oak. Since the staircase is already built with 2x10 treads, would it be accetable to simply liquid nail and tack the oak on top of the 2x10's? And, for the triangular shaped treads (which would be more than 20" wide at their widest point), would it be acceptable to do a solid oak glue-up (with biscuits), sand it down, and then liquid nail and tack this wide triangular glue-up to the 2x10's? Is this a splitting or warping risk?
If you don't like this idea, what are my other options for the wide, triangular treads?
Re: oak stairs
Re: oak stairs
Lee Schierer - McKean, PA
>Buillding codes require all tread heights to be the same. You could add the 3/4" material to all the treads, but that would make the first step and the last unequal in height now that the stairs are made. Adding a 3/4" thick piece on the bottom would create a 3/4" high step on your landing unless you cover the whole area.
Why not add commercial rubber treads over your existing wood. They meet applicable building codes and would be less slippery than tile or even varnished wood. A rubber pad at the bottom would not be a problem since it would be 1/4" or less in height.
Lee
Re: oak stairs
Re: oak stairs
Steve Silca
>Both the landings will be cement boarded and tiled, which should be about 3/4"-1" to keep the tread heights the same if I add 3/4" oak.
Thanks for pointing that out!
Re: oak stairs
Re: oak stairs
George Koch
>Steve, If you are adding 3/4" rise to both the bottom and top landings, you could use standard 3/4" oak floor on each triangled tread fitted into a standard 3 1/2" oak landing nosing. George
