>I am new to woodworking and therefore don't have a lot of equipment. For power tools I have a fix base/plunge combo router, jig saw, circular saw. I have been given a rough plank of Brazilian Cherry from which I'd like to make four table legs. Does anyone have any ideas on how to cut square blanks out of the rough plank without a table saw and planer?
>Hey Bill, thanks for your reply. I don't have other friends with the hobby so I'm pretty much teaching myself. I have built a couple of other tables but haven't yet had to deal with rough planks. Are you suggesting clamping a straight edge to my plank and cutting it down the middle lengthwise? To guarantee one flat side off which to base the others?
>You can use a straight edge and clamps or a guide system (which is essentially the same thing. Just cut your pieces the same width as your thickness. Then use a hand plane (something like a #5) and plane away. If you want to taper your legs, you probably want a smaller plane.
>Whatever you proceed with plan on some good, very sharp tools.
Brazilian cherry [jatoba] is wonderful furniture wood but is so hard that it destroys inferior quality saw blades. it is fun wood to work if your tool's edges are sharp.
>I knew a girl once who had no woodworking equipment but made a lot of furniture. She signed up for inexpensive courses at the local high school just to have access to the power tools.
Also, check around - there is a business near here that rents out woodworking shop time. You have to take a quick safety orientation course for each major tool. They have table saw, jointer, planer, drill press, lathe, router table, sanders, etc.
You could do it all with a bandsaw and jointer, or even with a hand saw and hand plane. You can also do a respectable job of jointing a side with a router and a straight edge if the thickness is not too great.
If you say where you live, someone who reads this thread may live close enough and be willing to help. It shouldn't take but a few minutes to plane and cut your board.
