Need desk construction advice
Ken Krawford
>I'm getting ready to build a desk like the one pictured below. Each pedestal will have 3 drawers. I'm a little puzzled as to how the pedestals should be constructed and then how they would tie in with the knee space. I'm going to use mechanical slides for the drawers.
Any help would be appreciated.
Re: Need desk construction advice
here is what I saw
Bill Tindall, E.TN
>That is an ambitious project.
I bought at auction a high end version of the desk you showed . (Never could have afforded a new one, or even the ones at auction except mine was missing a small drawer and went for $400 less.)
Anyway, the rails (the 4 horizontal pieces top and bottom, front and back, of drawer unit) for the drawers are mortised into what you are calling the pedestals. Everything is screwed into the robust top. It would seen that the top is what structurally holds it all together. You will be astonished what it will weigh when completed.
I built one years ago.....
John in NM
>In a shop I worked for (so I only have a vague recollection of it!). You build the pedistals as free standing boxes, each side frame and panel. Using ball bearing guides, you'll need an interior support for the guides, but you won't need dividers between the drawers unless you want them for the look. The privacy panel between the pedistals is just screwed to vertical cleats in the kneehole. What I can't remember is how I dealt with the middle drawer. I think I'd just have rails above and below and guides on the pedistals. As Bill said the top holds it all together and these things get pretty heavy, so its a good idea to make them to be dis-assembled - top, pedistals, privacy panel, etc. That way one person can move it and it can be as big as you like and all
the parts still fit through doors.
Joseph Mulherin, Sr
>Ken, I agree with John in NM as to how to construct the desk. Also, Norm Abram has a compouter desk on his website...www.newyankee.com...which might give you some ideas how to do it.
Years ago I modified a desk I had to hold my computer. I put the monitor on a slanted board in between the pedestals; cut a hole in the desk top and placed sheet glass on it to view the monitor; the printer was in the left side on a sliding shelf; and the computer was in the righthand side on another sliding shelf. I hid the wiring going everywhere with a panel like John says, and it really look fine for several years I used it... and the "ugly" computer and monitor were hidden out of sight.....
Nikos Annitsakis
>There is a plan and some costruction advice in the book "Desks" by Andy Charron. It is sold at Amazon.com for less than $10. The last project in the book is a pedestal desk.
paul in AZ
>I have an 19th century antique English desk along the lines of what you've illustrated.
It consists of 3 pieces: 2 pedestal 'boxes' and top that are separate pieces.
The pedestal boxes have 3 drawers each and have a footprint roughly the size of a modern 2 drawer file cabinet by around 25 inches high.
The top is about 7 inches thick and has a wide central drawer flanked by small drawers that match those on the pedestals.
The top is aligned to the pedestals by wooden cleats but is not screwed together. Gravity holds it in place. Believe me... it is heavy and stable.
There is no kick panel [privacy panel]. I suppose they could have added one easily enough by using a panel that slides down into a dado or slot created by cleats.
The main advantage of this arrangement is portability. The top is bulky and heavy enough to best need 2 people to move it. Once that is removed the pedestals are easy enough to move.
It would also be a lot less hassle to build in smaller components.
If you do yours in one fixed piece do some figuring on dimensions. My desk has a 60X33 inch top and is around 31 inches tall. That wouldn't go through a lot of doors.
The weight of a single unit desk will be impressive.
Re: Need desk construction advice------WebKitFormB
paul in AZ------WebKitFormBoundarynpfp2+MBuvclfBSM
Re: Need desk construction advice *LINK*
>I made a desk similar to that a few years back. There is a shop shot (see the link).
For portability reasons, I chose to make only 2 pedestals and the top. As mentioned by others, it is REALLY heavy. In fact it is so big I could not have gotten it into my home office in one piece.
Since this is a computer desk, I used a keyboard arm and mounted it to the top and made a matching tray.
I build the pedestals as free-standing units. They are made from frame and panel sides and backs. The back is connected to the sides using a combination of tongue and groove joints and web frames (which hold up the drawers plus one at the top and one at the bottom). The web frames are held in rabbits (I think 1/4" deep).
The carcasses are mounted onto bases which were made from custom made heavy (I think 1 1/4" thick) moldings.
The top was made as a frame and panel unit (3 panels) with Baltic birch panels on which I laminated bandsaw-veneer which I cut from the same wood that I made the drawer fronts from. Obviously, I started with 1/2" plywood and laminated both the top and bottom so it would not warp.
Email me if you have any specific questions.
http://www.woodcentral.com/shots/shot416.shtml
