A55 Smoothing Plane
Another 3/4" Wood Flooring Question
Ken Bellock (Houston, TX)
>I live in Houston, and down here, most houses are built on concrete pads with no basements. I am having a house built right now, and about a year from now want to install 3/4" hardwood floors on the first floor over the concrete pad. My plan is to put an 8mil plastic vapor barrier over the concrete, then lay a floating layer of 1/2" plywood on top of that leaving 1/4" gaps between the sheets. Then, I plan to put a layer of 15# felt down, followed by another layer of 1/2" plywood laid diagonally to the first layer of plywood and screwed down to the first layer of plywood only. Then I'll install the pre-finished 3/4" flooring directly to that using cleats and PL400.
My questions...
1. Is this a good plan for installing over concrete? I'm worried about moisture coming up from the concrete pad, and do not mind overkill.
2. This makes the total thickness of the floor above the concrete at over 1 3/4" thick. Other areas of the floor will have tile installed directly to the concrete pad. So that's a 1 1/2" rise from the tile to the wood floors. There are several areas where there will be a transition from the tile to the wood, and I'm sure that a transition between the two just isn't going to look very nice, or be very comfortable. Should I remove the tile, and install ply and backer board to bring the re-installed tile up flush to the wood floors?
Thanks for any advice!
Ken
Re: Another 3/4" Wood Flooring Question
Fred Davis
>Ken ,
after a year of curing the slab should be ok moisture wise , but to be safe , tape down a 6" x 6" square of clear plastic film like Saran Wrap and look the next day for collected moisture, if none , then hear is what I have done in similar conditions if the client approved and they always did.
There are some very attractive pre-finished Parquet hardwood floor tiles ( I like the hexagonal ones made in Sweden that interlocked) that lend themselves to this operation , better then boards do.
Just glue them down, using a fast set adhesive like PL400 rather then the Mastic the floor shops always push and takes days to set up and your done.
FredD
>FredD,
Thanks for the reply. I have been looking at putting down a parquet flooring in the office and dining room areas, and I saw in their installation instructions that they could be glued directly to concrete. If the cost is not too over the top to do the master and living room, I'll look into installing in there as well. Thanks again, and I will do your test to make sure the concrete has finished curing before installing anything.
Ken
Fred Davis
>Ken,
since it was early in the morning when I answered your post , I forgot a caveat about Parquet flooring offered in flooring shops.
If all they have is small squares of narrow strips linked together on the back by wires , then you are looking at junk.
If I remember the Swedish firm that sold though quality outlets in ca I will forward how to get in touch with a sample.
FredD
>FredD,
After your post I started searching for suppliers and just found "junk." I was actually coming back here to ask for suggestions for quality suppliers (especially if any supported Wood Central) when I saw your most recent post.
Thanks for your help!
Ken
