>I want to put a couple of non-structural beams from the front of the stage to the back of the stage in the theatre that I volunteer at. The beams will be used to support a pipe for side curtains for the stage. The length of the span is ~23' or so and it cannot be supported in the middle only on the two ends. It will be ~15' in from the stage floor.
So - I could get some wooden I-beams. I could get some aluminum beams. I could get some 2 x 6" or greater and put them together on edge. I could build some simple trusses.
Any opinions? It will only have to support the weight of the pipe and the curtains.
>JL, I would suggest you buy a couple wooden manufactured "I-beams".
The kind that use OSB and 2x3s. they can be painted to suit, will not sag, are structually sound and can be used to support anything else that happens along.
>I would consider building a hollow box beam out of some light weight material. If the curtain needs to slide, you could leave a slot in the bottom for some type of support for the curtain to ride in.
>I like Joseph's idea. These engineerd joists(like Truss Joist brand) can carry significant loads over significant spans, are readily available in several sizes, not tremendously expensive, and have joist hangers availble specifically for them. They are light weight but surprisingly strong. The lumber yard that carries them will help you size for you span and load. Quick and easy, prefabbed and cost effective-sounds like a winner to me.
>I agree with the manufactured "I-beam" but the manufacture needs to know that there will be no lateral support for the full span. Most of these are made to have lateral support when the subfloor ties them all together. (strong in the vertical direction but weak in the horizontal direction). If you have some idea of the weight of the curtains and supporting rods they can use that information. These normally are loaded from the floor load on the top and they may be able to adjust the bottom member to give you a better point of attachment for the rod hangers. Rather than two custom they may have you run two standard per span and tie them together for lateral support.
>Theater side curtains are several short lengths running parallel to the front of the stage, so that the view into the wings is blocked but actors don't have to push a curtain aside to enter or exit. If the ceiling is too high to hang the curtain from directly, it must have some kind of fly in space?
>fly in a pipe to hang them on, whichever orientation you prefer? I don't recall ever having to move our wing screening curtains, but I'd guess they were on pipes hanging from the top. I was more in the lighting end of things so maybe that's why I've got the fixation with pipes ;)
What do you intend to bear the new "beam" on? How are you attaching this new "beam" to....let say...the existing wall, the existing proscenium beam, etc. What is the existing proscenium beam carrying above it? Masonry, wood, metal studs? Are you hanging this beam from the existing roof structure? What's on top of the roof? Mechanical units, etc. Are you impeeding any automatic smoke vents? And if so, will your local code dept. allow such items to be built? You might want to just check into any Fire and Bulding codes for Additions and Alterations to a Stage assembly usage. Stage areas can be very susceptible to scrutiny from local inspectors.
Buliding rigging supports is the easy part, the other items above should at least be looked at or thought about. My 2 cents worth.
I'm no expert but:
Structural Drafting - 16yrs. plus experience and studying for my State Inspectors License. (Passed my Residential and Industrial)
For those who don't know what a proscenium is:
(proscenium - the part of a modern stage in front of the curtain c: the wall that separates the stage from the auditorium and provides the arch that frames it.)
"It will only have to support the weight of the pipe and the curtains.
What is the weight of the curtians and curtains? I don't know how many curtains you intend on hanging but they can be very heavy. Also, will the curtains be stacked at one end? (pushed aside for any reason) You now have a non-uniform load with the load bearing at one end. Curtains closed, the load should be uniform. Oh yeah, if the curtains get moved or pushed aside, your rigging has to withstand the dynamic loading of people tugging on them.
I know this may sound like overkill and you may be thinking I'm out in left field, but would you want this to fall down on someone?
I'm just saying that some real thought has to be put inot this.
I've said enough, I'm not trying to scare you, just trying to make you think about it some more.
if your familiar with Zono Tube , and the supported weight is not great, these waxed cardboard forms for concrete pillers are used frequently aroung stages.
Sorry I didn't get back to you earlier, I left the office after your reply. Be certain what your bolting into. Hilti makes a great product called RE500 anchors which are very good for what you are doing. Without seeing the building your dealing with I would still investigate what your attaching to. What thickness of block? Do the walls go from ground to the ceiling or as I mentioned yesterday, are you attaching to the portion of wall over the opening in the stage. (the proscenium) If so, then you really need to know whats over and what's supporting the wall above this portion. There could be a steel beam there.
Let me know if I can help more. Feel free to email at ~rcarson@hhpccse.com~
