>The sides of the keys on my keyboard are starting to get a buildup of what I call Crud. Anybody have an idea how to clean it off without ruining the keyboard? I constantly blow the unit off with 3M Dust Remover,(Compressed gas in a can).
>The crud is dirt attracted by the oil left by fingers. Mineral spirits on a Q-tip will do it as well as any other cleaners good for grease and safe for plastic.
>The keycaps on most -- but not all -- keyboards will pop right off. If yours is one of these, just pull off all the caps, toss them in a Tupperware container with some soap and water, and shake it up a bit till they're clean. Rinse and dry thoroughly, and then just snap them back onto the keyboard.
Helps if you have a picture of the keyboard when snapping the keys back on, no matter how good of a touch-typist you are. In fact, the better a touch-typist you are, the more difficult it will be to get the keys back in the right place. DAMHIKT.
My keyboard was filthy, covered with spills and food, so, to clean it, I first removed the back plate, the key membrane and the LED'. All that was let was the plastic exterior with all the keys which I then washed in warm soapy water. After I carefully and completely dried it, I reassembled and it was a good as new.
>I have actually put keyboards in the dishwasher! You have to turn OFF heated dry and then shake out the water and leave them in a warm place to dry out for a day or so, but it really gets them clean. These were for "extra" keyboards we had in the computer tech area, so I don't know if I'd do it for my main pc, since it might drive me nuts to wait for it to dry out. Not a good idea to use on a laptop keyboard. :-)
>I have cleaned a bunch of them using a Q-Tip dipped in hydrogen peroxide. It seems to do the job. With my luck if I tried to remove the keys or remove the back and whatever is inside I'd do something stupid and wind up having to buy a new keyboard. Being on a fixed income, that would have to wait till I get my share of the wealth.
>I've cleaned many keyboards. The problem is usually the gunk doesn't stay on the keycaps but gets into the switches and below. If it gets between the contact board and the conductive rubber contact on the bottom of the key switch that key can quit working consistently. I once fixed a truly "buggy" keyboard - a tiny gnat or something had gotten into the keyboard somehow and was flattened, preventing contact!
I use the way others have mentioned - disassemble, clean, reassemble. I clean the rubber contacts with laboratory grade ethyl alcohol but DNA should work. I clean the rest with a cloth or swabs moistened with water (the universal solvant) which is perfect for coffee spills, etc., then wipe with alcohol.
If the switches are sticking, the housing usually be pulled apart easily and lubricated with a smidgen of silicon grease. Don't lose the spring!
BTW, I use special programmable keyboards and rearrange many keys to greatly improve efficiency at my 3D graphics work. I move some keycaps around to suit - on all the keyboards I've tried the keycaps come off by pulling straight up. In fact, some keyboards came with a little wire cap puller.
