installing 3/4 flooring
Roger Mallory
>I am preparing a room to install 3/4� x 3 �� cherry flooring. Today I removed the carpet, tack strips and base boards.
The sub floor is � tung and groove plywood. The problem is I have a couple of low areas in the middle of the room where the joists are not the same level.
(I suspect my builder 19 years ago, did not install with crown up).
I have a full basement and the joists are sound.
In one area 2 joists are 3/16� lower.
What is a practical way to have my finished floor level?
Re: installing 3/4 flooring
GalenV
>Got any idea if the sub floor is glued as well as nailed to the joist?
If so trying to jack the two low ones will be tough to do. You did not say if joist were solid, composite or truss type and if any lacing between. You might get lucky and jack the low spot up above level and double up the joist. You could end up with a high spot!
This assumes you do not have a finish basement ceiling. If you don't mind a post jack left in place is another option.
Not sure I ever heard of using leveling compound on that large an area but maybe someone has tried.
Fred Davis
>Roger ,
If the crown of the joists in a spot or two or down , trying to jack it back level is a waste of time.
A couple of approaches you might consider .....
1. building the low spots back level with adjacent joists with 15 LB. felt ( also known as roofing or tar paper) .
2. Since I always bond flooring to the subfloor with PL 400 , this product has as one of its advantages , that it can bridge gaps up to 3/8ths of a inch .
Since the low spots appear to be about 3/16ths , this is a easy way to correct them, use a heavy bead in that area and let it dry before you work or walk on it and you will have a non-squeaking level floor that greatly increases the strength of the floor.
FredD
>I agree with Fred on this. After 19 years the joists and plywood have acquired a "permanent wave" and will be very difficult (almost impossible) to correct. You could try cutting the joists nearly all the way through, jacking them up and bolting and gluing another one beside them, but my experience is that this does not work well and may create as many problems as it solves. One definite problem is that you will end up with what appears to be a "structural" repair in the basement ceiling. If you ever decide to sell, the buyer and their Home Inspector (that would be me) will want an explanation. This might actually diminish the value of your house.
I would use a straight edge along the floor parallel to the joist and across the joists and if the gap were more than about a 1/4" I might try filling it with shim shingles or "feathers" I made myself. Glue them down and glue the floor, or just take Fred's advice and use the PL400 (good stuff).
Re: installing 3/4 flooring Thanks
Roger Mallory
>Thanks, one more question.
If I use the PL-400 would I not need a shim at the location where the nail is installed to keep the force of nailing it from pushing the flooring down to the subfloor?
a related question
jared
>In the next few days I will be installing 500 sq ft of 3/4 inch maple flooring. I have a roll of 15 lb roofing felt that I can use under the flooring. Should I use this or buy a roll of the pink colored rosin paper? Thanks Jared
Re: a related question
Roger Mallory
>I would use the 15# felt paper.
>I would be inclined to use the shims or strips in addition to the PL400. Just to be sure the flooring does not get pulled down by the nails.
This is somewhat unscientific, but I have had other brands of glue fail, but never with the PL400. So on something important like this, I would use PL400 specifically. Others may be fine, but I have confidence in PL400. (I am living with a failure in my house now of some other type of glue. Cooks get to eat their mistakes and builders get to live with them.)
>I might not use either. My research indicates the original purpose of the felt or paper under the flooring was as an air barrier. If the subfloor is boards, they are often loosely laid and in winter there might be cracks between the flooring, and that would permit cold winter air to blow through. If the subfloor is plywood or some other sheet product such as OSB there would be far fewer cracks. If the subfloor is T&G Sheet goods, there would be extremely little or no infiltration. So, if you are not worried about air leaking in, the paper or felt is unnecessary. This would include situations where there is a basement or other finished space below.
The paper or felt might serve as a cushion. This would be undesirable. Allowing the flooring to move is a cause of squeaks. And the paper or felt would prevent gluing the flooring down with the PL 400 mentioned above. (An excellent and reliable way of reducing squeaks.)
Fred Davis
>Barry is correct in stating that the felt or building paper is a vapor barrier . This is a old construciton practice related to subfloors being 1x6 or 8 or 10. Since the lumber was green when laid it has large cracks between the boards after is has dried out.
Modern subfloors in addition to being nearly airtight by theirselves, lend a additional strength to the floor when bonded by a adhesive such as PL400 and in fact has a engineering term applied to that ,called a "T Membrane" which is a very strong sandwich of the subfloor and joists and subfloor and wood flooring, acting in concert to loading and unloading of the structure.
FredD
Fred Davis
>If you let the adhesive dry as I said above, then it will not depress, that is the reason in the first place , to fill the gaps.
FredD
Roger Mallory
>Fred,
I realize that PL 400 will fill the gap, and I need to stay off of the floor until the PL 400 has hardened.
My concern was in the process of nailing the floor in place with my pneumatic floor nailer that it would depress the floor below level, so I would need to shim at the point of the fastener to keep the gap.
I will be purchasing several cases PL 400 this week for the install next weekend. The tube says it will do a 1/4� bead 32� per tube. Each tube should do one row of flooring. And I have 43 rows to install.
Thanks for your input.
Fred Davis
>Let,s see , I must be making myself unclear again.
The adhesive will harden and hold up the flooring without depressing when it is nailed.
That being said it is not necessary or even desirable to nail the flooring as much as you normally would without the adhesive, let the flooring float on the bed of adhesive in the low spots, if you will feel more comfortable shimming also , go ahead, its just a added step that once the Adhesive is cured is redundant.
AS for applying the adhesive, I always used a zigzag pattern on the back of each board.
I have seen installers who were in more of a hurry then me run a bead at right angles to the flooring about every 16 inches.
That would more then likely not be the way to fill a low spot.
I use the zigzag pattern from habit , as that is the way I apply glue in general.
If you use a minimum of fasteners and plenty of adhesive , it will be hard to go wrong. The fasteners like in any glue job , are used to hold the material in place until the glue dries, its the glue where the strength is.
FredD
Justin Szeliga
>In reading your post I didn't see you mention the depth of the joists & the span, or the spacing, all of which will be a factor in the sag & any permanent solutions. If the basement below is open & you can jack & shore the sagging area then that is the best solution. Installing a beam below the joists or sistering with deeper joists are possible solutions that won't just cover the problem over till the lumber sags a bit more from the weight of the floor & glue added to it. The joists most likely were installed crown up, after 19 years they'll sag. They will keep sagging a bit, especially if they are to shallow relative to the span or too widely spaced to carry the loads on them. You could check the ends, you may see a V or an arrow indication crown.
The whole construction adhesive thing sounds like a less than optimal solution. Building a beam & installing some posts will stiffen the floor considerably & some framing lumber may be cheaper than all the adhesive you may need. Less messy, too.
Peace
Justin
flooring
Fred Davis
>Always one in the bunch Roger,
but FYI, I have seen many joists, rafters , and long lintels like over the garage door installed upside down, by Carpenters in a hurry or were piecing the job or just not being attentive or were DIY's.
Actually as a fact, if the joists were the correct size and grade and the span not stretched , the joists will not sag , in 19 years or a hundred.
As Barry pointed out , shoring up of load bearing members after the fact will instantly attract the attention of a House inspector, competent Real Estate Agent, Home Insurance agents,and so on.
This invites unwanted attention by a buyer to structural problems.
The construction adhesive practice in most jurisdictions of Building codes , City Grades and Standards and Lenders (read FHA/VA codes) require at least the bonding of subfloors to joists/girders regardless of how messy it may seem to a untutored observer.
If conventional framing was followed in your home and there is probably no reason to think otherwise, the fifty to one hundred pound per square foot rating of your floor system would not be affected by the small added weight of the flooring and adhesive.
Quite the contrary, the adhesive bonding the floor to the subfloor , significantly increases the strength of the floor.
Since I would not wish to confuse or mislead you , my credentials as a Carpenter, Carpenter Foreman , Supt. of Construction, Licensed General Contractor, owner of several cabinet shops, and two incorporated residential construction company's makes me feel more then competent to advise you on your project.
But I digress .
FredD
Splitting hairs......
>The felt or rosin paper under the flooring is not a vapor barrier. Both are permiable (having a perm rate of over 1) and do little or nothing to resist moisture vapor. They were used as an AIR Barrier, to stop the infiltration of unwanted unconditioned air.
And, You are correct about gluing the subfloor to the joists. Gluing the right subfloor correctly can stiffen a floor by 25%. A very significant improvement at a reasonable cost. And, abosolutely the best way to limit squeaks.
