Humidity in the shop
David Dircksen
>I had a problem with mold and high humidity in my shop last winter. I just bought a dehumidifyer and was waundering what the humidity in the shop should be? Thanks for any info.
David Dircksen
Re: Humidity in the shop
Larry Marker
>Good question -- I try to keep my basement shop at 50%. It goes higher than that in the summer and a lot lower in the winter, but 50% is my summer target. (I live in northern Alabama.)
Larry
Re: Humidity in the shop *LINK*
Dale Lenz
>Check out the link below.
Air Quality
A Sideways look.......
>The lumber in your shop will equilibrate at a moisture content about one fifth the RH of the air. It's a rough approximation, but over time MC equals approximately 1/5 of RH. So, It is desirable for the lumber to be at about 6 to 8 percent, so you want the RH to be between 30 and 40 percent. So, if your shop is kept above 60 degrees (F) and below 40% RH your lumber will dry and you should not have mold growth or rust on your tools. If you have cold spots or the temp falls lower, you might have problems.
Why does the RH go up in winter? You are not venting the dryer in there are you? Does the AC keep it down in summer? Is the shop not heated? Is there a flue leaking into the shop?
Bill Tindall, E.TN
>I don't get rust or odors when RH is less than 60%.
