Followup
Mike Fitterling
>I guess I am not understanding what you have clearly.
Does the power come from the switch box or does it come down from the light box via two switch legs?
If the power comes from the switch box (and the light and motor are on the same circuit) the whites coming into the box from the panel should be tied together with the whites coming down from the fan box, and the black coming from the panel should go to one side of the switches. Then the blacks coming from the fan box should go to the other side of the switches, one to each. The grounds should all be tied together and to the boxes.
If the power is coming down from the fan box via switch legs, then from each wire the black should go on one side and the white should go on the other side of each switch. The whites in this case should have been marked as hot (black) in some manner, usually by a piece of black electrical tape at its end. In the fan box, then, the power coming in from the panel should have its blacks tied to the blacks going to the switch via the switch legs and its white tied to the white from the fan. The returning white wire coming up from the switches via the switch leg should be hooked to each black on the fan. Of course, the grounds should still be hooked to gether and to each box.
You have to know where the power is coming from to ge tthis right.
Good luck and be careful. Use a tester if you do not know which is which.
Mike
