Bandsaw dust collection..
Norman (Ottawa, Ont.)
>I finally hunkered down and made the hole in the bottom door of my bandsaw today :) This has been nagging me for a long time and I kept telling myself I would go ahead and get this done someday. Dust collection on the Delta 14 in. bandsaws is mediocre at best, no matter how effective my jury-rigged dust collection was at below the blade area, fine dust would get spun around the bottom wheel and get ejected again at the top. This bandsaw is almost the only remaining source of dust in my current shop.
I used a bi-metal 4 inch hole saw and located the hole as close to the bottom of the door as possible. A short time later and some cutting oil, it was all done. Some filing and sanding to get the edges of the hole smooth and remove any flashing.
Installed an angled 4 in. flange with posi-lock nuts , washers and short machine screws, set up the hoses to join together in a Y, and tested it. No more fine dust blowing out the top! Only a little larger and heavier dust which remains at the bottom of the wheel housing is all now, a huge improvement.
I feel like I've slayed a dragon :)
Norman
Re: Bandsaw dust collection..
Looks like . . .
steve mackay
>it came that way ! SWEET !
Re:under table pickup ?
Mike Hamilton
>Do you have a pic of the upper hardware? I'd love to see one if you do?
Thanks,
Mike
del schisler
>that is what i want to do to mine Where did you get the angled 4 in. flange ? I have look a little and didn't find one thanks del
>Good Morning Norman,
I did my last two Jet bandsaws the same way, and in about the same location in the lower door. DC was very much improved, and I get very little residual dust on interior surfaces.
George
wilbur
>Woodcraft has one. It's part number 144654.
http://www.woodcraft.com/family.aspx?FamilyID=899
>I generally hate to cut up my tools to add dust collection or for any other reason. I broke down and cut a hole in the door of my Delta bandsaw and was not happy with the results. Collection was not as good as I thought it should be and the hose fought with me tooth and nail when I tried to change the blade. It "spring loaded" the door and would close it every time.
I talked to Louis Iturra at Iturra Designs and he told me Delta makes a pickup port for these saws and he sells it. About $35. I studied it and realized I could make one out of an "end" boot for four inch ductwork. $5. It mounts on the side under the table and picks up the dust through the original hole. I took the little plastic vacuum port off and use the original bolt as an anchor for an eyebolt that holds the port on.
I was ticked that Delta did not mention the port that came with the saw and called them and told them. They sent me a new door to replace the one with the hole in it. (I gave that one to a fellow WC'er for his ancient saw he was fixing up.)
The port I made works well and does not require hacking a hole in the door. A wing nut allows it to come off to change the blade.
>Mike,
Pic attached of upper dust chute. It comes with magnets so it attaches directy to the bandsaw casting after removing the puny 1.25 inch dust pickup assembly. Lee Valley has these...It pops off easily enough for maintenance.
Also, I have a quick release band clamp to remove the hose going to the angled flange for blade replacement and any other reason to open the door. I don't change blades often, mostly keep the same 1/2 in. 3 TPI blade in for almost everything from resawing to crosscuts to rips.
Norman
>Mike,
Norman
Alexander Grigoriev
>I cut a 2" vacuum attachment (nozzle) and attached it into the door. See the picture and following. By the way, it's Grizzly bandsaw.
Alexander Grigoriev
>This is another view
Alexander Grigoriev
>Last picture, when the door is almost closed.
del schisler
>thanks for the info on the item del
Re:Alexanders's dust pickup
Ray Carson, Lawrenceville, NJ
>Alexander,
Great idea. I like how you thought of nylon bolts in case the blade gets too close for some reason. Brilliant !!
Ray
Re:thans to all for pics
Mike Hamilton
>I have a mid-60's Rockwell Delta 14 incher and need to add dust extraction. Mine has the doors on two bolts rather than hinged. Plenty of open opportunites around the edge for dust to go everywhere.
Mike
Alexander Grigoriev
>Who would have thought, but today I backed the workpiece off the running blade and it seized in the kerf and went off wheels. Of course, the nylon bolts got cut, but the blade didn't suffer any damage.
Re: Bandsaw dust collection..------WebKitFormBound
wilbur------WebKitFormBoundaryjSlgBISU+kkaqA8s
