200+ woodworking book reviews
ot-engine temp gauge
fred in ct
>i have a 2000 ford ranger 3.0 eng. yesterday and today the temp gauge pegged on hot and the idiot light came on after about 1 mi of driving on a cold engine. as soon as i started to pull over the light went off and the gauge returned to normal.no trouble driving the rest of the day. fluid level is good.maybe a bad thermostat? thanks fred.
Re: ot-engine temp gauge
Bill White
>Thermostat or sending unit.....
Bill
Get a new thermostat
Lee Schierer - McKean, PA
>The thermostats on Fords that I have owned (2 of them) have all died at around 60,000 miles. In my cases the car took forever to warm up to get any heat in the winter. Once the thermostat was replaced I would get heat after about 4 miles of driving.
If yours is failing to open, you could find yourself walking.
Lee
Re: Get a new thermostat
John_in_Az
>I've had a similiar problem with the Ford guage on a different vehicle. I don't think it possible for engine to get to hot from a cold engine in 1 mile. The most likely problem is the connection from the sending unit to the guage because it suddenly returned to normal. Check out the wire connection at the temp sending unit, clean it good and put a little dialetric grease when reconnecting. It could be the temp sending unit itself but not as likely as a bad connection.
Jesper, Denmark
Re: No chance....
Jesper, Denmark
>...that the cooling was hot enough after 1 mile. Replace the sending unit.
It ispretty cheap and easy to do, so while you are at it, a new thermostat is always a good idea - but it had nothing to do with the problem you describe.
Re: No chance....
Ed Wozniak, Buffalo, NY
>Fred said that both the temp gauge and the idiot light indicated that the vehicle was overheating. Does the idiot light and the temperature gauge both operate off the same sending unit?
Jesper, Denmark
Re:I dunno, but........
Jesper, Denmark
>The engine was not overheating after 1 mi(nute)or 1 mi(le) of driving.
Jerry Nicholson
>In addition to the other comments, you might check to make sure that all the air has been bled out of the cooling system. I have had situations where there was a bubble in the system and the sensor was sitting near the highest point, leading to very high readings.
Jerry
Actually, can happen
Bill Houghton, rainy in Sebastopol, CA
>If a thermostat's not opening at all (sticking shut), and you're flogging the engine hard enough, you can get up to very high temps very quickly. I've had it happen, followed by the same pattern of events Fred describes. I don't think it's common - the bimetal spring more often fails open, or opens slowly rather than not at all - but it does happen.
Thermostats are cheap and, in most cars, a fairly simple replacement - regardless of whether or not the sending unit's bad, replacing the thermostat makes sense, even with the little hassle of losing some coolant.
Sending units, on the other hand, get hidden in the most inaccessible places, so cleaning up the connection and ensuring that it's right may well use up some of your inventory of bad words.
Bill, spent half a morning while camping with the family years ago replacing an oil pressure sending unit that the maker had decided to put behind the exhaust manifold and which, when it began leaking, spewed oil all over the hot manifold, scaring the daylights out of his sweetie (and, well, yes, himself).
