OT TV Converter Box??
Sawman
>So I have the coupon for the converter but now I am faced with what brand?
Saw one at the local Radio Shack. DigatelStream?
What kind should I stay away from?
Sawman
Re: OT TV Converter Box??
John McGaw
>I got one of the Digital Stream units and put it on a small TV at my Mom's house. It seems to work as well as the slightly more expensive unit I got at Circuit City (can't remember the brand). None of the uber cheap units will have any bells and whistles but all should give you a viewable picture. Just remember that you won't be getting a real digital image but something once removed and it will definitely not be HD.
Only needed if you use an antenna
Joe Pack
>You probably know this already, but...
Converter boxes are only needed if you get your TV signal through an antenna. If you have cable, dish, etc., you probably will NOT need a converter box.
I was at a box electronics store a couple of days ago and happened to overhear the "expert"a telling an older couple that they only had a few more months before their TV would be "obsolete." Of course, the new, expensive LCD/Plasma screens they were selling would work just fine. Being a buttinski when I hear BS being fed to people who don't recognize that they are being gamed, I butted in and asked if they had cable. When they said, "Yes, we do," I told them their old set would work just fine with cable if they were satisfied with the picture they had now. They thanked me for the information and walked away.
Funny, the "expert" forgot to thank me.
I didn't mind him trying to sell a TV, but I did mind him not telling the truth to a couple who were not savvy enough to recognize his BS for what it was.
Re: Only needed if you use an antenna
Tom MacGregor
>I was using an antenna in a fringe area - total of four channels & two came in with snow & static. The converter box is less forgiving of a marginal signal and the sound & picture were terrible to unwatchable on two channels. A larger antenna with a two piece booster amplifier run with new RG-6 quad-shielded cable fixed the problem - for another $250 bucks plus my labor.
The peak of my house seems to have gotten a LOT higher than it was last time I was up there 12 years ago!
LAWRENCE MATHESON
>Been using a Zenith box for several months and like it very much. Purchased it from Radio Shack for $20 after the $40 coupon. We get about 30 channels and the picture quality is better than what we get with DirecTV.
Tony - Memphis
>I've been real happy with mine so far. No issues. I have two hooked up to antennas in the attic and I get great reception. Much much better than the the analog signal - no ghosts, static, etc.
Tony
Re: OT TV Converter Box?? *LINK*
Mike Circ
>You might want to look at this instructional video on hooking up the converter boxes.
DTV Video
GalenV
>Is digital TV going to be transmitted on the same carrier wave as analog and therefore the element lenghts of your old antenna correct for digital? I forget a lot of this theory. Think there has been too many waves passing through my body.
Mike Jurnigan in Suffolk
>Question for those that have theirs already. Do you have to have a seperate box for each TV or can I split the output from the box to each TV?
Thanks in advance,
Mike in Suffolk, VA
Curly Smith
>You need a box for each TV unless you want to watch the same program on both TVs. The same holds if you want to record one program on your VCR while watching another on your TV - you need a converter box for each. You might also need an amplifier if the signal isn't strong enough to split (DTV is all or nothing, if you have enough signal strength then you get a picture but below the threshold you get nothing).
Rich in Mn
>DTV is using the UHF channels for transmission. So yo need an Antenna that will receive the UHF signals. Most newer antennas were designed for both VHF (which will go away) and UHF (which will be all digital next year.
Tony - Memphis
>I don't have cable, so I had a dilemma. All my recording devices were analog and the converter box is not programmable (ie no timer). So, I ended up purchasing a new DVD recorder with a digital tuner. It works great. I have my old recorder hooked to a converter. I was surprised how different the quality was between the two. I record some things on the old DVD recorder hooked to the converter box (have to make sure the box is on the correct channel!) and the quality is much better than the analog signal from the antenna, but still not very good compared to the new recorder with the built-in digital tuner. Huge difference. I have the signal from one box split between the tv and the old DVD recorder. When both are on and I'm watching the signal from the DVD to the tv, it is pretty bad (loses color). Not a problem since I never watch tv with the signal coming through the DVD recorder, but something I noticed. All this from a guy who has no cable because he doesn't watch tv! Ha! Actually, we don't watch much, but I got tired of watching what we did all fuzzy and ghosting and squashed on on old standard ratio tv (new ratio shows were 12" tall - no kidding).
Make sure you use your discount cards before they expire.
Tony
49.95 from walmart, works fine
robert davis
one for each tv
robert davis
Re: 49.95 from walmart, works fine
robert davis
>$10 with caed
Like minds
>"...Being a buttinski when I hear BS being fed to people who don't recognize that they are being gamed, I butted in and asked if they had cable....
Funny you should say that. I find myself doing the same sort of thing, usually at electronic stores or computer stores, but sometimes at Home Depot. I cringe when I hear people being feed BS and usually step in. Sales people don't like me much.
Happy Woodworking!
It's funny, really...
Jason Roehl in Lafayette, IN
>...because when you do it, the sales people's hands are tied. If they object to your intervention, they're likely to lose not one, but two potential sales then.
I guess it's just amazing to me that, with the internet and all the access to product info we now have, sleazy, high-pressure sales tactics are still even used. I guess P.T. Barnum was right...
Jason
Michael J Bitetti
>Use of the VHF band for television will NOT go away. Some stations will broadcast their SD and/or HD signals on VHF. Both bands will continue to be used. I only say this because I was hoping to be able to go with UHF only myself. I strongly suggest checking your local area for direction, distance AND frequency band before making an antenna decision.
Mike
