Stock Feeder
Stock Feeder
Stock Feeder
Dave Winters
>We have a small feeder for our shaper, and it only has one speed, which is quite fast. Looking for ideas to slow it down some. One suggestion was to use a rheostat like those for routers. Would that work? Any other suggestions? Maybe there is different gearing....
Thanks in advance..
Dave
Re: Stock Feeder
Rick L
Re: Stock Feeder speed change...
Rick L
>You can't use a rheostat. You can't use a router speed control as they are only for motors with brushes. All the feeders I've used have gears that can be swapped to change speeds. If you change the motor to a DC type you can get a special rheostat. A three pahse motor and a VFD will allow infinite speed adjustment within 50% of the range. Get a new feeder would be your cheapest option or change the gears.
