Applying finish in cool temperatures
Alan Young
Alan Young
>Ok- How vital is to apply a finish in temperatures above 50 degrees, or even higher? My shop is in my basement and as such I can usually get pieces finished year round. However I am now chasing the calendar on a large project that I have moved out to the barn for assembly and finishing. The barn has lighting but no heating. So temperatures will be seldom or at least randomly above 50 degrees for the coming months.
The project is a long set of cabinets which are fastened together in a pretty much final state.(They could actually be disassembled but it would be more than a major hassle)
I haven't settled on a particular finish-but there will no staining -just a top coat of a shellac, varnish, urethane etc...
The doors and drawers can/will be taken back inside and even the long top can be removed if necessary. So I guess I'm really looking at just getting a finish on the face frames. So what really happens to finishes during cooler temps????
....working a barn turning "red to blue"
Alan
Re: Applying finish in cool temperatures
Can you heat the space temporarily?
>Fast drying finishes might be forgiving enough, Alan, but not slow-drying oil or varnish finishes. For those, consider firing up a torpedo or salamander heater for a while and get the room temperature up to room temperature or better. Don't forget to turn off the sources of ignition before you start unleashing solvents into the air.
I do it all the time!
Lee Schierer - McKean, PA
>Chemical reaction type finishes require the temperatures stated on the containers. Evaporative solvent finishes like lacquer or shellac do not require any given temperature to "cure". I sprayed lacquer in my unheated barn from a spray can this morning with the temperature at 38 degrees. I have brushed on Deft clear wood finish for years at freezing temps with no problems. It merely takes longer for them to dry. Years ago I even asked Deft if it was okay and they clearly said that their finish was not temperature sensitive except for the drying times shown on the contianer would be longer.
I don't think most of the water based finishes or the polyurethane solvent type finishes will cure at the cooler temps.
Lee
Rob Stokes in North Vancouver
>I've done it before - just tented the project, heated it up with a couple of ceramic space heaters and made sure the project was warm (not just the air around it), removed the tent, applied the finish, set the tent up again and kept the heat running on low making sure it drew air in from outside the tent so no (potential) combustibles went across the element. Piece of cake!
Rob
agreed with one exception....
Bill Tindall, E.TN
>Hell will freeze over before varnish will harden at 50 degrees. There is a problem with lacquer and shellac that can be exacerbated at low temperature and that is condensation of water vapor on the piece as it cools from solvent evaporation. You had better think of some way to preheat the piece before application and keeping it warm until whatever finish hardens.
I sprayed some lacquer yesterday at 40 degrees, but got the piece to a warmer (and hence less humid) environment quickly to evaporate the solvent. It ahs been at 60 degrees or so for 36 hours and it still stinks, indicating the solvent has not fully evaporated and hence it is not fully hardened.
Alan Young
OK It's apparent
Alan Young
>that this needs not just warm enough ambient tempts but the wood needs to be at warmer temps too....I'll be re-assessing the logistics.
Thanks all....
Alan
Re: agreed with one exception....
>I agree that regular varnish will not cure in cold temps, because I believe there are polymers being formed in addition to the evaporation of the solvents. Varnish generally does not redissolve if the solvent is applied.
I have never had a moisture blush problem, but then I don't often spray my finishes in cold weather. I rarely preheat the wood and many times the wood has been in the unheated area for days at a time as the finish is applied to one side at a time to prevent runs since it takes longer to set up. You do get some nice smooth flows on the surface so brush marks are minimal due to the slow evaporation.
Lee
Alan Young
"Luckier than I should have been"
Alan Young
>That's what my dad always says when things go his way in a tight situation....I was very happy to find out I didn't need to take the unit apart any more than removing doors and drawers. The low bank of cabinets is fastened together and those connections are covered with plywood-so separating them would have been a major hassle.
The top component cabinet is separate from the lower cabinet bank so with the help of my two great sons, we were able to slip the units back into the shop where although space is tight-I'll be able apply a varnish in adequate ambient temperatures. Alan
Some misinformation here
Michael Dresdner
>Some of the above is not quite true. Some finishes will cure at low temperatures, and some will not. Most oil based finishes will cure down to about 45 degrees F, but they will do so very slowly; so slowly that it may seem as if they are simply not curing at all, but they will, eventually. Lacquer and shellac will both cure in surprisingly low temperatures, mostly because there is no chemical reaction other than evaporation taking place, but again, more slowly. With all the above you must be concerned with getting cold enough to hit the dew point, which can cause moisture problems, so it is indeed wiser to heat the wood, the finish, and the room to a reasonable degree, and keep an eye on the humidity as well.
The real problem finishes are the waterbornes, which will often not form a film at all below a certain temperature. Most need a bare minimum of 55 degrees F, and are way happier if it is above 70. There are, however, some cold weather waterbased paints on the market.
Don Burton
>For the staining operation, I've had really satifying results from NGR stains such as Solarlux, or alcohol soluable dye stains. They dry so fast that moisture isn't a much of a problem.
On the finishing, my choice during adverse weather conditions such as were described would always be a lacquer. Deft in particular, seems to loose any blushing that might occur, even fairly heavy, after a couple of hours.
I love shellac as a gorgeous finsih, and regularly use dewaxed shellac as a sealer coat under varnish and lacquer, but if the weathetr is adverse, I forego any shellac for the reasons stated. Shellac and high humidity are enemies of each other.
