REAL MILK PAINT
Way OT-Telephone jack problem
Dave Bair, Eaton Rapids, MI
>I have two phone jacks and a jack connection for my computer. Yesterday, I was painting in the kitchen and I removed the wall phone so I could paint behind it. As the paint was drying, I tried to make a call from the bedroom phone. The line was dead. I plugged it into the internet connection and that was dead too. I plugged it into the kitchen connection, and it works fine.
I've tried various combinations but as long as I keep a connection in the kitchen jack, all the lines are live. The connection right now is just a jack and about 8" of phone wire; no phone or anything else is connected to it. If I unplug the kitchen jack, I loose the other phone and my internet connection.
My seperate lines all run from a single "hub"; a hardwired connection secured with small wire nuts, one line in, three lines out. Any idea what the problem is?
Re: Way OT-Telephone jack problem
anon e moose
>It sounds like your telephone jacks are connected daisy chain style throughout your house. You probably have a loose connection on the jack that works that is not allowing the signal to get on down the chain. The push on terminals used on many jacks don't tolerate being moved very much or very often. Reterminate all the connections and most likely your problem will go away.
Lee
Check Kitchen jack for short
Terry in Edmonton
>Unplug the jack in the kitchen and look to see if the any of the 4 small wires have jumped out of position and are touching another wire. This is not common but it does happen. When you plug into the jack the shorted wires are pushed apart and a connection is made. Unplug it and the short returns. It will probably be one of the center 2 wires.
Should this be the case you can usually get the wires to go back into their grooves with some very gentle persuasion.
I suspect Terry's right
Tim Greif - West of Chicago
>Replace the kitchen jack and I'd predict the problem will disappear. If you have a VOM meter, check the voltage between the red and green wire on one of the other jacks with and without the kitchen jack connector plugged in. My guess is you'll see about 40-50 volts dc with the kitchen jack plugged in and near zero-volts with it disconnected. That would confirm that the kitchen jack has shorted the red/green wires with the plug removed.
