>Any recommendations for a good traction tire? Only got 12,000 miles on the tires that came with the truck. Didn't rotate the tires and didn't think it would make that much difference in terms of wear. Guess I was wrong. Thanks for your help.
>My Dodge Dakota came with Goodyear "tars". I have faithfully rotated and now have 67,000+ on 'em. I'll buy them again. Also had Toyo tires on a Sonoma with good success. Key is inflation and rotation.
>Personally, I like Big O if you have them where you live. When I did field work I ruined a lot of tires and their warrantee was free, and they didn't hassle me about sidewall gashes from sharp rocks. Their high end highway tires also have a very good treadwear rating, and they'll rotate and balance their own tires free. I'm surprised you only got 12,000 on a set, they should go more like 60,000 at least. I'd have thought you could rotate at 15,000, so either those tires really suck, or there's some problem causing them to wear out. I'll assume you're not peeling out every chance you get ;).
>This is a good site to compare auto and truck tires based on customer satisfaction surveys and pro reviews. Play around a bit and you can find more information than you may ever need.
>As someone else has said 12,000 miles is way to low a figure to wear out a set of tires these days. I would suspect an alignment problem. As far as tire dealers go check out Discount Tires if you have one nearby. Best prices that I have found around here.
>from my motorcycle tires. There's something wrong.
I have 2000 Tundra that I bought used 40K ago. I don't remember what tires were on it originally, but I got about 65K out of them. A year ago I got a set of Kelly Safari Trax at the recommendation of my mechanic. So far they've been good.
My Tundra seems to be a bit sensitive to both alignment and rotation, (but then my town has really bad streets) so bear that in mind.
>Agree with the others. 12K for new tires is way below spec. Most new cars have 50K warranties on the tires. Check your paperwork.
BTW- it might help if you tell us where they were worn. Sidewall, tread, one side vs. other?
Steve
P.S. I drove down with a guy on an access road to Rose Creek in the High Sierras on a "dirt" road. Her told me he went through a set of new tires ever few months on his fullsized Dodge Ram @1500/set. The gold he retrieved from his claim paid for it all :-)
>I got 36,000 miles on my original tires on a 2002 Tundra. So I think you have a problem that you do not want to put a new set of tires on until you fix the underlining problem.
>Thanks everyone for your comments, I'll check the alignment. BTW-the dealer essentially told me to p-off and wouldn't do anything to help considering that I bought a Camry when I bought the truck.
>have worked Very well for me. I started using them about 25 years ago. My last two vehicles were full sized custom vans (3/4 ton). I did use the LT tires, switched to the SUV style the last time I bought some. I also pull a trailer quite a bit (hauling lumber etc.). I have averaged over 50 thousand on every set. Just bought a new (to me) 1996 GMC Savana with 68K mi. I exchanged the Michelin (SUV tires) between my old Dodge van and the GMC before I sold the Dodge. They have about 10K on them and look like new. I have never had a blowout or flat on the road in the 25 years I have used Michelin. I do keep the alignment checked about every 50K mi. - but have never rotate the tires, I just bought a set of Michelin Hydroedge for my wife's 1991 Chrysler Lebaron convertible last week. I would have the alignment checked before I put new tires on your vehicle - just about any tires I have seen should be good for at least 30K - most new vehicles have a 50K tire warranty (don't know if the tire warranty is worth much though, years ago I tried to replace a tire (US Royal) that failed on my new Chevy in about 12K. With the credit allowance the tire still cost as much as some other brands retail. I haven't had a US Royal on a vehicle since then (and never will).
>One of my daughters bought an S2000 sports car. The tires specified for it are high performance tires. They DO last only approximately 10,000 miles. The rubber used is very sticky but soft and wears quickly.
After replacing her tires (at ~$200 each!) once, she opted for a more reasonable tire with a hair lower performance but much more reasonable life.
As for alignment and tire inflation - these show characteristc wear patterns. If wither or both are the problem you should be able to see it on the tires. Take some pictures for your records if this is not the problem.
I bought some (name-brand) truck tires for my pickup some years ago and they were NOT warranted for tread life. I'll never do that again! They did last a reasonable number of miles though.
>Yeah, we got bit...we have a 350Z and the tires don't last long. Sort of ridiculous for driving on city streets. Love the car, but between brakes and tires, it ain't cheap. I forget what brand they are but they are huge and the fronts and rears are different and they are directional. Noisy as heck too once they wear a while.
>with the Yokohamas on my Mitsubishi Evo. Pretty much bald at 10K. I replaced them with a set of slightly less aggressive Michelins which, while still giving good performance, have a good deal of tread left at with 15K miles on them, & look like they'll go another 10K anyway, which is not bad for this type of tire. The new rubber is also better in the wet, and since their sidewalls are slightly less stiff, the car's very firm, performance-oriented ride is improved somewhat.
When I replaced the original tires, I tried the online source Tirerack.com. Their price on the tires I wanted was excellent, even with delivery, and they gave a list of several local tire places which would mount the rubber. I opted for one that came to my house with a truck containing the needed mounting/balancing machines. I pulled the wheels myself (which I prefer to do anyway, since I don't trust the impact-wrench-happy installers at most tire places to torques my lug nuts properly), they removed/mounted/balanced the old/new tires in their truck, & I reinstalled the wheels. Whole thing took about 30 minutes. It all went very well, and I'd definitely use this method again.
>I have had several sets of GF Goodrich tires for my trucks. 3 sets of All Terrain TA on my Jeep 4X4 and 3 sets of Long Trail TA on my Ford 2X4. All of these got 60,000 miles out of them or more. I have also used GoodYear and Kelly Springfield with less luck. Yup, over 500,000 miles on my 3 trucks, so I know about tires.
One thing about my BFG's is that they don't degrade on the traction area. My K-S's got hard after 1 year and never had the same traction. The Goodyears lasted about 40,000, but otherwise were fine.
My 2 cents. Buy the best BFG tires you can. Do NOT buy some no-name or local tire as the UV inhibitors are not used as much.
>My daughter had a new Mazda S2000 4x4 some years ago with Firestone tires. When Ford had the tire problem with the Indiana plant. Se had 100,000 miles on the tires when they replaced all 5 including an unused spare with a complete new set.
