Handy effective shellac application devise
Bill Tindall, E.TN
>I am fond of shellac for some applications but I find it a difficult to apply. While it can be sprayed, it is finicky about blushing and running. For a small job, spraying is not handy.
I have not been successful brushing shellac. The brush must deliver a continuous film of material. Any interruption and there will be a lap mark. I don't own a brush that holds enough material to be reliable. And then there is the expense and time of cleaning the brush. Well, actually ladies (and strange "gentlemen") make-up brushes are good for small jobs.
One can pad on thin coats. It works fine but it is way slow for my taste.
One day I tried a foam "brush". Foam holds vast amounts of shellac which is what is needed, and it delivered a uniform film. Indeed the disposable brushes work great for a short session. After a bit the alcohol disintegrates the gray foam.
I found this limitation surprising because urethane foams are typically extremely resistant, but apparently not that which brushes are made from.
Someone sent me something packed in 1/2" thick white urethane foam. I fashioned a brush from it and found it worked great. (nothing dissolves white urethane foam) I have used these homemade brushes for applying shellac and stain to objects on the lather (eg. pens) as well as small jobs at the bench. They hold amazing amounts of material, just what is needed.
As an example of a recent application, the picture shows some 1/4" quarter round molding for some door panels. The "brush" is a 1 x 1 x 1/2" piece of foam tacked to a stick. One light dip in the 2# shellac solution and I could do 2-3 of these molding pieces before reloading. The film goes on uniform and dries smooth. I applied the water soluble stain the same way. Its delightful and no clean up.
