A55 Smoothing Plane
Chair Finish Question
Bill Tindall, E.TN
>I bought some unfinished cherry ladder back chairs from Haley Daniels in Berea (I think they are more comfy than Boggs and a lot! cheaper). Our various chairs finished with lacquer get scratched easily and the scratches don't look attractive. I have a son in law, and another to be, and they both carry huge clip knives that have furthered the scratch problem, but that is another issue. On the other hand, the lacquer gets scratched and not the wood.
Would an oiled finish be better for a chair? Or, what is best for a chair that wears well? The chairs are informal so oil would look ok.
Re: Chair Finish Question
Glenn Madsen near San Francisco
>I'd do shellac over oil, but then, I do a lot of shellac over oil.
It's a wipeable surface, quick drying, easy to repair, and cheap to apply. By the time the second chair is finished with a coat, the first one is ready to wipe again.
But that's just me. My grandkids aren't easy on chairs, either.
If you want an oil-looking finish, consider Waterlox Original, also wiped on. See a trend here? ;-)
>I've used Waterlox Original, Tung Oil and BLO/Poly mix on different chairs. The most durable of those has been the Waterlox. As to what looks the best? It depends on your preference. I usually don't put anything over the oil except wax. But then I'm a lazy finisher.
Larry Barrett
>Bill
I have made a number of similar chairs, usually red or white oak, but also some in walnut and cherry. I use walnut oil (thinned with mineral spirits) as a finish. Wipe it on and let it dry overnight. If you want to spruce up the chair after a couple of years, just reapply the oil finish. I use hickory bark for seats, and apply same finish on the bark. If you are using something else, like shaker tape, be sure and cover the seat before applying finish.
Re: where do you get the hickory?
Larry Barrett
>Hi Bill
The best hickory I have found comes from the guy whose chair you did not buy - Brian Boggs.
He doesn't always have it, but has had some extra for the past couple of years. Not cheap, but good quality.
I have bought some from other sources - try basket supplies. I thought it OK, until I saw what Brian had.
