REAL MILK PAINT
Making a rosewood try sqaure.
Virgil Johnson
>About 10 years ago I started making this rosewood square. I roughed out the handle, cut the blade to length and then stashed it away to let the parts �age� and the wood reach equilibrium with my shop environment. Yesterday I got an email from Ellis who will be passing through town in route to the Woodworking in America Hand tool conference in Berea KY. Naturally I had to view the Woodworking in America web site. http://www.woodworkinginamerica.com/GeneralMenu/
First thing I saw was the sold out message. Just as well cause with a kid in college I don�t have the 335.00 to pay the admission. After seeing that Bridge City Tool Works was an exhibitor I immediately remembered that I was supposed to finish the square this weekend as the pieces had reached the end of their 10 aging process.
The overall dimensions of the square are 6� x 8 ��. The blade is 1/8 x 1 �� A2 or O-1 flat ground stock.
The blade is held in place with (4) 3/16� steel pins pressed through 3/32� brass stiffeners inlet into the side of the rosewood handle. The 3/16 pins were cut from a piece of drill rod and are peened into place.
Re: Making a rosewood try sqaure.
Virgil Johnson
>I ground the blade edges straight and parallel to .0003 (yes I can measure this close) before mounting to the handle. All of the parts were cut to size and the holes drilled and reamed before assembly. The holes in the blade were drilled with a .005 offset to pill the blade tightly into the slot cut into the handle when the pins were pressed in. If I make another I'll make the parts a line to line fit. The .005 offset combined with .0005 press fit on the steel and brass made for a tight fit.
The handle was milled square to the blade after assembly. When I checked the square it was out .001 over the 8� length of the blade. I'm sure it will change a bit when the humidity in the shop changes.I wiped on a coat of BLO on the handle.
Glenn Madsen near San Francisco
>I'm not going to Berea either, for seven or eight good reasons.
But Virgil, that's a mighty nice looking square. The ten year aging process MIGHT be a little overkill, and the accuracy a bit much for my shop, but from here, it looks like you did very well. Good on you!
Hope the folks in Berea have a good time without us!
Really, really nice !
steve mackay
Dale Lenz
Re: Very Nice, Virgil
Dale Lenz
>I'm impressed!
Fred Davis
>Virgil,
has about the same sense of urgency for projects to make when he get's the time, as I have for this Dantesque chair from Italy made about 1525 and donated to the Philadelphia Fine Art Museum By Baroness Van Doorn.
Carlyle Lynch made a measured line drawing of it for a 1959 DeltaGram book and I am just now getting to it. ;-))
FredD
Fred Davis
question
Bill Tindall, E.TN
>would you please elaborate on your statement....."The handle was milled square to the blade after assembly." Did you harden the blade?
Nice job.
>Good Morning Virgil;,
That is more art than a beautiful tool. I'd be afraid to use it in my shop. Are you actually going to put it to use, or is it for display purposes only? Its too beautiful to drop on the floor.
George
Answer
Virgil Johnson
>I held the square in the milling machine vise by the blade and cut the wood to form a true right angle. The blade is soft.
Virgil Johnson
>George, Thanks for the compliment. I'm going to use it.
