Bandsaw Tire Replacement
Tomm
>Should both of the bandsaw tires be replaced at the same time? I am starting to notice a rougher cut even with a new blade. I was thinking of only replacing the top tire since it is the last tire the blade contacts before the cut. The bottom tire is still crowned and the blade still tracks well over it. Thanks for your comments.
Re: Bandsaw Tire Replacement
Howard Acheson
>Always replace both tires at the same time. If one is bad the other is not far behind.
Digressing: tire material
>You didn't ask, but I'd like to make a pitch for the urethane tires. I've got a little 12" bandsaw, 1940s dinosaur brand, for which factory tires stopped being available probably 60 years or more ago. When the existing tires died, I purchased urethane replacements, which have been great. Stretching them on wasn't easy, but, from what I've read of gluing on the rubber tires, probably easier.
Re: Digressing: tire material
Bill White
>Urethane is the way to go. Put 'em in boiling water for a bit before you attempt to install them. They'll stretch just fine.
Bill
