Floor Finish
Brian in Cheyenne
>I have wide red oak t&g flooring which has already been stained and finished previously. The finish used was polyurethane, but after a few years, the finish is already beginning to show wear and tear. I'd like to refinish the top coat of poly.
Will a good sanding be all that is needed before putting down 3-4 coats of new poly? Should I use something other than poly? 9I would have considered tung oil derivitives, but with the poly already on there, I think this option has been eliminated.)
Any suggestions? Thanks!
