REAL MILK PAINT
Need finishing advice - curly red maple burl...
Scott in Douglassville, PA
>Hi, all -
I'm getting ready to place a small order to Lee Valley. In order to optimize the cost/shipping ratio, I thought I'd plan ahead and order finishing supplies for the spokeshave I'm building, too. The stock is curly red maple burl. I want to emphasize the figure as much as possible - I'm guessing that there'll be some sort of dye involved.
Anyone have some suggestions on how to finish this wood? I'm out of my zone a bit with this one.
Thanks,
Scott
Re: Need finishing advice - curly red maple burl...
Chuck in ND
>Clearcoat it.
Glenn Madsen near San Francisco
>I was thinking the same thing, but more specifically, shellac. An amber or blonde shellac should be just the thing, and it will feel great in your hands, too. Just pad it on, and come back again, and do another coat in an hour or so. Repeat as long as you think it needs it.
Will Abbott
>I would use BLO and water based poly. I love the way the oil makes the figure stand out. Make sure the BLO is cured before you use the poly or you will have problems.
Re: Need finishing advice - UPDATE
>Hi, all -
One of my projects over break is going to be the spokeshave I started a while back - the one using curly red maple burl. I ordered some cherry dye stain and tried a test tonight. The attached shows the wood, wood with tung oil finish, and wood with dye stain and tung oil finish. I be happy... :^D
Scott
