Bandsaw blades
Carl Willis
>I have a Craftsman Band Saw that takes a 72 5/8 inch blade. It is maufactured discontinued. Do you know where I can purchase blades for this bandsaw?
Thx,
Carl
Bandsaw blades
Carl Willis
Thx,
Carl
Re: Bandsaw blades *LINK*
Dave's Not Here
Suffolk Machinery
>I searched Google for bandsaw blade 72 and found a bunch at Ace Hardware, eBay, Olson, Dremel, and others.
Re: Bandsaw blades
GalenV
>Sears store at least in Des Moines Iowa has a few blades that are 70 1/2 so got to believe they would work for 70 5/8 as only a slight difference in center to center and tensioner should allow. Think they are limited in width and teeth per inch selection. I know they are slowly going out of 80" selection I use too.
Re: Bandsaw blades
Joseph Mulherin, Sr
>I have the Shopsmith bandsaw that uses 72 1/2" blades. I found them at Lowes
Re: Bandsaw blades
GalenV
>Probably my luck but about two months ago bought a 1/2" x 80 4TPI blade at Lowes. It busted on the weld the first time I used it. Went to Sears and got replacement and still using. They are probably both made in the same country and put in different packages. Just how my luck goes.
The secret about bandsaw blades
Thomas S Stockton
>Is that they are all custom welded off a roll of stock so it is real easy to purchase oddball lengths. Most areas have a shop that makes up blades but there are a fair amount of online sources also The link provided previously is a good choice.
Tom
Re: The secret about bandsaw blades
>I haven't tried it, but my books say it is a relatively easy matter to cut and assemble your own blades.
Mike in VA
>Try Suffolk Machinery / Timberwolf blades. They will make them any length you want. Plus, they are very good blades.
http://www.suffolkmachinery.com/
You're 46 Hours Too Late
Dave's Not Here
Oh Well. My Bad!
Mike in VA
